i had my FM tuner replaced by service today, and there's a note on the invoice that if the problem happens again i will have to pay to have it fixed because of my portable XM Onyx unit.
seems to me this is a BS response, considering the issues with the FM tuner are well document both on this forum and elsewhere on the internet...and it's clearly not my portable XM unit that caused any issues (not to mention i had seen the issues before ever installing XM). people use antenna adapters to wire the XM FM direct adapter into cars all around the world of many different manufacturers without any issues, all it's doing is inserting the XM signal in on an FM frequency and cutting out the regular FM frequency. there's no reason that should be causing any issues with anything in the car. i had disconnected the adapters before taking the car in for service, so i'm not sure how they even can say i had ever modified anything to begin with.
my understanding of magnuson-moss is that they can't void the warranty unless they can prove that your modifications caused the issue, which in this case i think it's pretty clear they did not. i'm trying to get my ducks in a row to be prepared in case this happens again and i have to take it back to have them replace the tuner again...anyone have any insight on how to handle this?
Customer has aftermarket XM radio wired inside center console. If issue occurs again it will fall under customer pay as modifications were made to system.
