Linking a Driver Profile to a Key You can link a driver profile to a specific key to allow Model S to automatically select the correct driver profile when the linked key is detected as you approach the vehicle and open the driver's door. To link a driver profile to a key, enter Model S with the key and touch Controls > Settings > Driver Profiles on the vehicle's touchscreen. Select the driver profile you would like to link to the key, then touch Link to Key Fob.
Note: Model S only detects one key at a time. The driver profile is linked to the key that is detected by the vehicle at that time. Therefore, if you want to link driver profiles to multiple keys, ensure that only the key that you would like to link the driver profile to is within detection range while performing the linking procedure. Move all other keys outside of the detection range (at least three feet (one meter) away from Model S).
Note: Model S can support up to three linked keys. However, a driver profile can only be linked to one key. To remove the link between a driver profile and key, touch Controls > Settings > Driver Profiles. Select the driver profile, then touch the X next to Linked to Key Fob.
