Anyone have definitive proven way to keep ac running while sleeping overnight?
Discussion in 'Model S' started by Francis Lau, Aug 9, 2014.
Tags:
  1. Francis Lau
    Francis Lau P-1456
    Bellevue, WA
    Sorry if the info is somewhere in the forum already but does anyone have a definitive proven way to keep ac running overnight while sleeping in the MS? Sleeping in the back and not in the driver's seat. Preferable from someone who has done it, not ideas and theories.:biggrin:
    Thanks.
  2. jerry33
    Texas
  3. plaeuschler
    plaeuschler Member
    Wetzikon (ZH), Switzerland
    I believe this was the Video where Bjørn found the trick:
    Bjørn's Tesla Model S #7: Sleeping in The Car: Bjørns Tesla Model S #7: Sleeping in The Car - YouTube
    Didnt watch it again but if I remember correctly you need to put the car in neutral and engage the emergency break instead. Not sure if you can charge while not in park though.
  4. Johan
    Johan Ex got M3 in the divorce, waiting for EU Model Y!
    Drammen, Norway
    Can't charge at the same time. Only way for that is to activate HVAC every 30 mins manually or with the app or 3rd party app (Visible Tesla)
  5. mgboyes
    mgboyes Member
    United Kingdom
    Have not done it, but the summary of much discussion on this topic is:
    If you don't need to charge then by leaving the car in neutral with the parking brake manually engaged.
    If you do need to charge then by putting a heavy object (80lbs or more) on the driver's seat to simulate a person, latching the driver's seat belt, and then after the weight is already in place pressing the brake pedal to turn the car "on".
    If you have a laptop and both it and the car can get a data signal, by using VisibleTesla's scheduler to wake the car up and start the AC periodically through the night.
  6. Francis Lau
    Francis Lau P-1456
    Bellevue, WA
    Thanks everyone. Great summary @mgboyes. I will read the links everyone provided.
  7. JPP
    JPP Active Member
    SF Bay Area, CA
    You don't need to have your computer with you for VisibleTesla to do it's thing. As long as your computer (wherever it is) is awake and connected to the Internet, and your S has a good data connection, you are set. And if you are away from your computer, and need to get very creative, use Logmein or another remote access app so you can telnet into your computer and make changes to VT as needed.
  8. SteveW25561
    SteveW25561 Member
    Vancouver, Canada
    Wouldn't it be amazing if visible tesla had a way of receiving commands sent to it via something like if this then that, or via an email? Ifthisthenthat could even set up an SMS way of activating commands. Obviously security is paramount, but it might make for cool additional functionality. Imagine SMSing a command to say "set AC on til 8am" and then getting a confirmation email or SMS back from VT. It would need a at running on a PC at home. I personally have VT running 24/7 on my Mac at home so I can log trips etc.
