So I have two Tesla's charging and between that and a number of computers, I'm qualifying for R-4 Time of Use metering:
National Grid - Time of Use
Which I thought was good, but then after trying for weeks to find someone there who knew what R-4 time of use metering at National Grid was, I'm getting back this:
National Grid Customer Service -----------------
What is the rating of the batteries in your cars in kW?
The standard rate for the distribution charge is a little over 6 cents per kWh. Ont the R4 rate the On Peak Distribution Charge is 14.859 cents per kWh and the Off Peak Distribution Charge is 4.328 cents per kWh. So your on peak distribution cost more than doubles (about 8 cents per kWh more) and the off peak distribution cost is only about 2 cents less. So for every kWh used on peak to get any savings you need to use about 4 kWh off peak to break even and more than that to get any savings.
If you do change to the R4 rate it will take us some time to get the meter as we have to special order them and you have to be on the rate a minimum of 1 year.
Which kind of seems to be saying "Yeah, we'll let you access cheaper off peak electricity, but then we are going to increase your on peak electricity charges... because...because we say so."
Yeah, doesn't make sense. Unless they did a deal with regulators saying "We'll give citizens access to cheaper off peak electricity. (But we'll up their on peak costs! ha ha ha ha ha!!!)"
So my question is:
* Has anyone hooked up National Grid R-4 Time Of Use to Tesla Charging?
* Was it worth it?
* What's the deal with National Grid R-4? It doesn't really seem useful unless you only use electricity at night.
* How can we have our states allow citizens charging cars with cheaper off peak electricity, without dinged with an increase on peak.
So my question is:
* Was it worth it?
