Anyone in SE Michigan go through the process of getting a second meter from DTE?
Process was seamless except for the expected issues with getting the city inspection on the work being up to code. Very happy with the second meter on the PEV rate. I had two outlets installed in my garage, just in case I decide to park in a different spot (or buy a second Tesla :smile:).
Only issue with DTE was that they were underbilling me for about 6 months; I had to call them to get it fixed and then paid a hefty bill in accumulated charges.
I had solar panels so the solar installer brought in the electrician, then, he took care of the 14-50 outlet and the meter housing. The next step was to get city approval that it met code, then DTE was called to install the meter.
As mentioned above, it also took around 6-9 months for DTE to get the billing correct, and in my case because of the solar, and my summer production, I ended up with a big credit that should carry me through most of the winter.
Now that I'm at a proper keyboard, let me expand a little bit on my previous comment. I started out contacting DTE last fall to see if their incentive program was still operating – they had one where they would install an EVSE for free. (Well, up to a certain limit.) The program was over, but to my surprise they contacted me several months later to tell me a place had opened up, so I got lucky. They hooked me up with a contractor, and since they were picking up the tab, I did not feel the need to shop around. I was happy with the contractor they sent.
Although I'm sure the incentive program is long-over by now, I was left feeling impressed that the DTE employee who told me she'd get back to me if anything changed actually got back to me. In my experience, this is almost unprecedented. It was also clear at the time that the DTE employee actually knew something about Teslas and which contractors were experienced doing installs for them, so even if they aren't paying for it, I suspect they would be a good place to go for a referral.
By the way, make sure you save your receipts from your install. I'm not sure whether Congress renewed the program for this tax year or not, but last year EVSE installs (including NEMA 14-50) were eligible for a tax credit (subject to AMT blah blah blah check with your tax advisor blah blah blah).
Edit -- Oh, maybe you already have your NEMA 14-50 and all you need really is just a meter. Even so, I'd save the receipts and check with your tax advisor, unless it turns out to be so inexpensive that it's not even worth bothering.
They recommend putting in a 100 amp feed into the second meter which is what I did I now wish I had done at least 150 amp. I have two EV's Tesla 85D and a Chevy Volt. With both my cars charging at the same time the Model complains about the current and lowers the charging to 30 amps which is not enough to fully charge overnight from empty. Of course this has only affected my 2 times in the last 4 months. But if I get a third this will definitely be a problem.
Digging up this old thread as I am attempting to get a level 2 installed in Oakland County. I am currently awaiting a response from DTE/Vehya after I spent $100 from what it seems for a online assessment. I have a 100 amp service panel & not looking to upgrade it. I intend on obtaining a 2nd meter from DTE & hard wire the level 2 charger to it for power & EV charging rates. Has anyone go through this process & can share their experience? I was told by an electrician coming out to give an estimate that DTE will deliver & install the meter without charge. Is that true? Thanks! These superchargers are getting to much love from me & anxious to start charging at home.
Any update on this? looking to start the process as well
