Hi, I'd like to install an aftermarket subwoofer and amp in my Plaid. I haven't found anything on the web as of yet as to how to get this done. Please excuse my ignorance if someone has already posted an answer to something like this.
Kiss your warranty good bye with this upgrade, good luck trying to explain this to a Tesla SC if you have any issue with electronics in the car. I am sure they will blame this if you have a window open/close issue!!Matt Schaeffer explains in this vid
After talking to XS batteries. I don't think you need to step down the voltage depending on you're amp and battery selection. As long as the amp you choose can handle the higher voltage. Depending on the battery you select the battery can handle the 15.5v. XS recommended xp950. For just a subwoofer I you don't really need all of this extra input switching equipment. Just tap the sub in the back and you'll be just fine.I'm also waiting on a more viable option. I don't like the idea of having to install a battery to supply the 12V needed for the amps. Also, even more, the idea of switching inputs sounds horrible.
Don't car audio support 10v-16v? I suspect he installed the 12V battery because the car has a 16V low voltage circuit right?
Are you doing a subwoofer? If so you can probably get it off the connection points of the subwoofer in the rear. Right at the subwoofer.Hello. Looking to do an install in the new plaid, where is the best place to pull left and right speaker for a line out converter? Don’t want to pull apart door panels if I don’t need to. Thanks
Hey Sean…how did your second battery install go? What isolater did you use? Would you mind sharing a basic diagram or pictures of how it’s wired and where you tapped into the primary battery or charging system?OK I can probably help you guys understand this issue with an aftermarket sub in the refreshed s and x and the new Li-Ion 3 and y. It will the same issue across the board. All of these variants will required a secondary battery. Maybe with a lower powered amp (150w)you might be able to get away with it. The Li-ion battery in these vehicle are great for durability and reliability but not for inrush current and relative small storage capacity which isn't good to run amps. I believe the LI battery capacity is around 6.9 Ah vs 33 Ah on the previous Lead Acid battery How do I know, I've had to replace my Li ion battery because of trying to install a JL HD750. After talking with Matt from the YouTube video above, I'm going to give it a go again but with a secondary battery and a battery isolator installed I'm also going to fuse the secondary battery from the primary battery with a 30 amp fuse as . This makes the install process a little more complicated but it shouldn't be that big of a deal.
No not at all. The lc2ipro uses audio turn on and works the best for turning on and off the system. You should have to worry about isolating the batteries.Awesome! Thanks Sean! I see you didn’t use an isolator. Are you having any issues with the new amp battery draining the car battery? Especially when the car is off?
If ur going to go the added battery route make sure u get the 14v battery. Not the 12v on the AMD systems. The the AMD tesla charge at 15.5v. The 14v battery rated charge level is 16v. So the battery will always be slightly under charged somewhere in the ballpark or 90%. But undercharging is better than over charging on the 12v batteries.Great to know. I noticed in your photos that only one red positive cable is connected to the top battery post. Where are you connecting the power cable to the second battery from the jump terminal? Thanks again!
Got it…have the 14v on order. Did you use a side terminal on the second battery for the positive feed from the 35amp circuit breaker? Again appreciate your help.If ur going to go the added battery route make sure u get the 14v battery. Not the 12v on the AMD systems. The the AMD tesla charge at 15.5v. The 14v battery rated charge level is 16v. So the battery will always be slightly under charged somewhere in the ballpark or 90%. But undercharging is better than over charging on the 12v batteries.
Here's the pics from my upgraded install. I still need to carpet my fiberglass box but it sound amazing. Tesla don't really rattle because of all the sound deading they have.Got it…have the 14v on order. Did you use a side terminal on the second battery for the positive feed from the 35amp circuit breaker? Again appreciate your help.
