Anyone know a good electrician in san diego
Discussion in 'California' started by tcrcnsx, May 12, 2015.
Tags:
  1. tcrcnsx
    tcrcnsx Member
    san diego
    Getting a EV meter next month and want to wire it up to my garage with a wall charger. and does anyone know the cost ?
  2. trils0n
    trils0n 2013 P85
    SF Bay Area
  3. Hometheatremaven
    La Jolla CA
    I highly recommend Robert Guillory, owner of Calray Electric. He has installed many Tesla boxes for our members, including mine.
    Look him up on Yelp. He's honest, competent and reasonable. He's very busy. Give him a call.
  4. tcrcnsx
    tcrcnsx Member
    san diego
    #4 tcrcnsx, May 12, 2015
    what kind of charger should I get ? Should I just buy a tesla charger or go with aftermarket charger like leviton or juicebox ? are you guys getting 30 or 40 amp using the charger that comes with the car ?
  5. RandyS
    RandyS Fan of Elon
    San Diego
    I can help with questions about the EV meter, since I work for the local utility. What were you thinking of?
    As far as charging speed, you can put in a higher powered or a lower powered charger, but I find that a good barometer to use is "how many miles will you be driving every day"? The charging station I would recommend would be different if your answer is "20" vs. if it is "75"...
  6. ggr
    ggr Expert in Dunning-Kruger Effect!
    San Diego, CA
    I second that.
  7. tcrcnsx
    tcrcnsx Member
    san diego
    At my mom house she got a leaf with a 240 charger that she got for free and free install . When my brother goes over and use it , he is only getting 30 amp max. Will you get 40 amp ? If you get ev meter and plug in from there. And are you supposed to get 80 amp if get the tesla charger ?
  8. GoBlue88
    GoBlue88 Member
    Carlsbad, CA
    I third it. Calray Electric installed my NEMA 14-50 outlet and did a great job for a reasonable cost.
    - - - Updated - - -
    The Tesla HPWC will give you 80A on a 100A circuit if you have dual on-board chargers. Otherwise you'll get 40A.
    A 240v plug like a NEMA 14-50 should give you a max of 40A on a 50A circuit.
  9. tcrcnsx
    tcrcnsx Member
    san diego
    I will give Calray Eletric a call, thanks for all the info
