Anyone know how to get a replacement toolkit for the Roadster?
Mar 27, 2016
160
336
Woodland Park Colorado
I just dropped of my brand new (to me) Roadster for its annual service and, apparently, the toolkit which comes with the car is missing. I spoke to the previous owner and he never had it either.
The Tesla service center (St. Louis) doesn't have a toolkit either and cannot remove my wheels to finish the service.
Does anyone know where/how I can at least get the tool to unlock the wheels?
wiztecy
2,905
563
Can't remove your wheels!?!? Tesla service centers should have the master keyed set to remove any Lotus wheel locks which were put on the Roadsters. I'd call a local Lotus repair shop, the real Lotus one. And see if they have the master key and if they can pull it off. I'd then buy another star lug bolt and the star extension / key and your good to go. I wouldn't worry about anyone stealing your wheels, anyways the pro's can pop off those lock lugs just as fast as a regular lug, they give the owner false confidence.
Toolkit won't have the lock key. You can buy that at the Lotus shop and I'd think Tesla could order one too.
Habious
420
132
Springfield, VA
I did what @wiztecy recommended...bought 4 "standard" lug bolts (they're bolts, not nuts) and removed & replaced the 'security' ones.
One) they're not that secure and Two) if you don't have the tool (or the tool strips...which I've seen happen)...you're dead in the water.
Habious
420
132
Springfield, VA
P.S. The most important thing in the toolkit is the tow hook adapter. It threads into the hole behind the front license plate (assuming you have a front plate installed). Make sure you've got one of those adapters in the car.
wiztecy
2,905
563
I heard the tow hook threads are different. Sounds odd to me, why would they create a new thread when the tow hook is already available direct from Lotus. Possibly MAUTO or someone how has a Tesla Roadster and a Lotus Elise/Exige can verify that the tow hook is or isn't compatible between the two cars.
ML Auto
709
713
SW Florida
The tow hook is different. The roadster uses larger threads, probably due to the extra weight. The metal bracket that it screws into has more attachment points to the crash structure as well.
You can buy a spline tool for the lug bolts from an auto parts store that sells "tuner" lug nuts with the same 10 spline size. I bought a several from O-Reillys in the past. Only $10 if I remember correctly.
racevpr
53
165
Phoenix, AZ
Of the 4 Roadsters we have, each one came with a different master key for the locking lug nut.
Take a picture and check Ebay for Lotus master keys and match your pattern.
Doug_G
Lead Moderator
Apr 2, 2010
17,877
3,337
Ottawa, Canada
I bought them from Tesla several years ago. They weren't cheap... but they weren't $30 each either!!!
Sounds like you can get them from a Lotus shop.
bart513
1,327
92
East Hampton
I haven't been able to find a replacement kit either. I'm trying to remember what was in it? The tow hook, allen wrench for the hard top, lug nut bolt remover?
