Anyone know what this new white connector is on the driver side?
Discussion in 'Model S' started by pointbob, Sep 21, 2014.
Tags:
  1. pointbob
    pointbob Member
    Washington
    Havent seen it in previous pics, so thought I would check with the collective....
    VIN 40K+
    I had tried to test it and looks like a 12+v (however only received a blip and a whine/spin down and gone. I can see it is an empty connector and goes back into the wheel well and cant see the rest.
    Thx!
    -Slick
  2. FLDarren
    FLDarren Member
    Seminole, Fl.
    Take some more pic from a distance. I can't make out where on the driver side that is and I've taken apart most panels on the car.
  3. pointbob
    pointbob Member
    Washington
    Here is a 'zoomed out pic'
    Thanks!
  4. Al Sherman
    Al Sherman It's about THIS car.
    Batesville, IN
    Isn't that where the Service Center plugs in their laptop?
  5. cgiGuy
    cgiGuy Active Member
    Everywhere, Nowhere
    No, this is the ethernet port:
    #33
  6. pointbob
    pointbob Member
    Washington
    the new connector has solid green and black only two wires not 4
    agree with cgiGUY
  7. invisik
    invisik Supporting Member
    Minneapolis
    Yeah an Ethernet port needs (at least) 4 pins, that looks like it has 2.
    -m
  8. AmpedRealtor
    AmpedRealtor Well-Known Member
    Phoenix, AZ
    Maybe it's a harness for a forthcoming side mirror camera... :)
  9. tga
    tga Supporting Member
    New Hampshire
    Granted, I'm being more than a bit pedantic, but Ethernet ran pretty well over 2 conductor coax (wire+shield) for 10 years before 10base-T came along requiring 4 wires.
  10. invisik
    Minneapolis
    I switched from Arcnet to Ethernet at the 10baseT era (was so done with coax cabling) so I'm a little late for that one..... :)
    -m
  11. SkiWA
    SkiWA Member
    Washington
    Probably for an option you didn't get? Do you have fog lights? They probably run the same wire harnesses in all the cars to save time and only hook up the options that you have? Just a guess...
  12. pointbob
    pointbob Member
    Washington
    Still baffled...any other suggestions?
    Nope. Only option I didn't get was premium lighting.
    I wonder if I was in the transition period for the additional sensors or lane departure wiring harnesses before they actually put it in...
    D
  13. Johan
    Johan Ex got M3 in the divorce, waiting for EU Model Y!
    Drammen, Norway
    Maybe it's for a future ACC upgrade?
  14. invisik
    Minneapolis
    Could be for ambient lighting, it does add a light in each door. I'm actually trying to track down the leads for the ambient lighting circuit. Are the leads to the plug black and yellow?
  15. pointbob
    pointbob Member
    Washington
    There is one on the passenger side as well
    I took the passenger side sill off and there is one that is also attached on the other side.
    Green and black.
    Any further clue?
    I was able to get a voltage to it, but am afraid that I may have shorted it out.
    I checked every fuse in both boxes and all intact but now I cant get a voltage.
    Was looking for a switched 12V (hard wire a valentine one...BTW it works in the ez pass area just fine, and Fuse 75 in my car is absent) or ambient lighting terminations.
    Thanks
