Anyone? Loud buzzing noise when supercharging
Discussion in 'Model S: Battery & Charging' started by Trnsl8r, Feb 19, 2014.
  1. Trnsl8r
    Trnsl8r S85 2012-2018, X90 since 2016, 3 since 2018
    San Jose, CA
    Hi all,
    Curious if this happened to anyone else. Family and I came up from a long road-trip to the Gilroy supercharger with 24 rated miles left on the battery. It was about high 60's outside. We plugged in, saw we got only some 30kw, so changed to a different charger and off it went to 89kw as expected (not sure if swapping chargers is relevant, and yep, I have the A-pack).
    As we were packing up our stuff to go browse the store, we heard a relatively loud buzzing noise coming from the car, mostly from the front. It was hard to define but sounded... electrical. Curious, I opened the driver's door to check the monitor. As soon as I opened the door, the noise stopped. Nothing special on the monitors. Closed the door, waited maybe 10 seconds and then the noise came back. Opened the door again and the noise instantly disappeared. Closed, waited, noise back.
    I called Tesla Service, gave my name and explained what happened. The guy said "yeah, I'm watching your car now, everything looks normal". (I'll never get used to driving a computer... :)) He also speculated that there was a vibration in the cooling system that neutralized from me opening the door, which sounds plausible. He said he would put in a ticket for me to come in and have it looked at. (Not ten minutes later I get a call from my local service center to set up an appointment. Wow...)
    When we came back the noise was gone and car was up to some 190 miles and everything has seemed normal since. I have a few weeks before the appointment, but to kill time I thought I'd see if anyone else had this happen?
  2. EarlyAdopter
    EarlyAdopter Active Member
    Redmond, WA
    Have you ever cranked your A/C to max and listened outside the car? Give it a try and see if it's the same sound. The A/C compressor can get really loud on max. You probably were hearing the A/C keeping the batteries nice and cool while the car was Supercharging at 89kW.
  3. Trnsl8r
    San Jose, CA
    :-/ ... not so sure... I've heard the fans go bonkers before, but this sound was different. Also doesn't explain how the sound could come to an immediate stop as soon as I opened the door.
  4. pimp-boy
    pimp-boy Member
    Los Gatos
    I have the same issue you have. I'm at "rated 70 miles." Charge at 120kw. No noise until it hits roughly 100 rated miles. Buzzes all the way to 170 miles and then slowly gets quieter as the charge rate reduces. One SC says that is normal due to the AC cooling the batteries and that Elon is looking for a way to muffle the noise. When I open the driver door, sometimes, that noise goes away. I'm bringing it to a 2nd service center for other issues and to check it out and see if they say the same thing.
  5. Zextraterrestrial
    Humboldt/Los Altos
    was your climate control turned on? (when you opened the door)
    this might change the way heat is routed through the heat exchangers?
    I noticed that at some point my car had a deep pitched rumbly vibration while supercharging, I didn't note the SOC or charge rate at the time but it was bad enough that i could not be in the car for more than a few seconds without feeling nauseous. Almost sounded like a garbage truck was outside next to me.
  6. Trnsl8r
    San Jose, CA
    It was... although not to the extreme. Set at 70, with about 66 outside (and sunny though) with Eco mode on. Still odd that the sound died literally the same second I opened the door though...
  7. brianstorms
    brianstorms Member
    A few times when it was really hot out and the car was hot and I happened to be at a SuperCharger, I've found my car's cooling system to be SCREAMING within a few minutes of starting to charge, as it attempts to try to cool down the batteries (or whatever it is the system is doing).
  8. pgiralt
    pgiralt Supporting Member
    Cary, NC
    I've noticed the sound while supercharging as well and it is exactly the same sound as the air compressor when it goes full blast in the middle of a really hot summer day. I also noticed the same thing that it stops when you open the door and this actually concerned me because the charge rate doesn't slow down which makes me think that there is less cooling going on. Even if you don't close the door, it will eventually ramp itself back up again, but I still don't understand why it stops when you open the door.
  9. towatana
    towatana Member
    San Jose, CA
    Did it sound like this?
    VIDEO0002.mp4 - Google Drive
    I asked about it at Tesla SC and was told this is normal when battery cooling kicks in.
  10. Chris TX
    Chris TX Active Member
    Dallas, TX
    Yep. The first time I Supercharged, we were sitting in the car when that sound happened. It started low and slow, then crept up to a full on scream. The silly thought of the car exploding did cross my mind, as it was quite unnerving. You could hear it outside the car, and I narrowed it to the fans sucking air through the two coolant radiators under the headlights. The vanes in front of those radiators were open and a HUGE amount of air was sucking into it.
    Kinda scary, kinda awesome, mostly cool.
  11. Trnsl8r
    San Jose, CA
    That's it, thanks a bunch. Maybe I'll just cancel that appointment then...
  12. SFOTurtle
    SFOTurtle Active Member
    Los Altos, CA
    I had this happen a few days ago in the late afternoon at the Vacaville SC. It was maybe 65F, and I didn't have the AC on and didn't open the door, but the sound eventually subsided and disappeared. The next day I Supercharged at Gilroy in the morning, and the car didn't make a peep.
  13. SCW-Greg
    SCW-Greg Active Member
    Beaverton, OR
    #13 SCW-Greg, Feb 19, 2014
    Yes I'm certain this is normal operation. Mine does the same when Supercharging, even at temps in the 40's. When you're dumping 120kW on the pack there is a lot of heat/resistance created. Heat is the enemy on battery life, so keeping them as cool as possible, is the goal.
    Not sure how the AC pump is doing double duty (in theory) for both cabin and batt pack, unless it's a separate pump.
    My daughter's boyfriend actually was apart of the development team for this motor (third party company). It was chosen because it's a super efficient DC system. I need to ask the name of the company.
  14. Zapped
    Zapped Model S - PURE EV
    YEG <-> PSP
    I've heard that sound also while supercharging at Atascadero. The battery was almost empty but the sound did go away as the battery filled up.
  15. brianman
    brianman Burrito Founder
    Yes.
    Yes.
  16. gelden
    gelden Well-Known Member
    Breda, Netherlands
    Mine does that sometimes even when charging at home.
  17. VolkerP
    VolkerP EU Model S P-37
    Germany
    AC fans going frenzy could indicate a sub optimal clima agent level in the AC system. Probably due to leaks, sometimes when the system is overfilled. SC should have a standard procedure to check the AC system's efficiency. Could anybody ask for the results of the "AC performance test result"?
  18. scaesare
    scaesare Well-Known Member
    NoVA
    I think the car goes in to "Ready for pilot entry" mode when you open the door, and does several things: slightly rolls down the window, starts waking up consoles, decides if cabin HVAC needs to be activated, determines if it needs to illuminate the charge port, etc...
    Given that the HVAC system in the Model S supplies cooling capacity for both the battery as well as the cabin, it's likely that the system is momentarily giving the cabin settings priority. I'd guess that if you stood there with the door open and did nothing for a bit, it would resume as the battery pack demanded additional cooling.
    - - - Updated - - -
    The system appears to be a single compressor system supplying cooling capacity for both the pack/drivetrain thermal management systems, as well as the cabin cooling via heat exchangers. It also uses wast heat from the motor/inverter to in turn provide heat for both loads as well.
    I started a thread on it with a diagram as well as as some patent explanations here at: Thermal Management
  19. andrewket
    andrewket Well-Known Member
    I've used SCs a handful of times and have never heard the cooling system in my car kick in like that. This includes last summer in 80F. Weird.
  20. scaesare
    NoVA
    Yeah, actually me neither... I've heard the cooling kick in some, but not full bore like that...
