Anyone LR AWDs Showing 322 Miles Fully Charged?
Discussion in 'Model 3: Battery & Charging' started by diezel_dave, Dec 3, 2019.
  1. diezel_dave
    diezel_dave Member
    Utah
    I know the Tesla site shows LR AWDs having 322 miles of range now but when I charge my car to 100%, it still reflects the old range of 310 miles. Anyone's cars showing the full 322?
  2. XLR82XS
    XLR82XS D M C
    SWFL | Vegas
    Yep - 322 at 100% SOC.
  3. diezel_dave
    diezel_dave Member
    Utah
    Interesting. Mine was built only a few days ago and it only goes to 310 miles at 100%.
  4. thefortunes
    thefortunes Active Member
    Wisconsin
    That's because (I believe) you have the stealth performance.
    The performance models (mine included) only display 310.
  5. Joshan
    Joshan Member
    Chicago
    never done a full charge at 20k miles.
  6. coconutboy84
    coconutboy84 Member
    Ontario
    I don’t know why people are scared of 100 percent charges. They are fine every so often especially if you drive the car right after it’s done charging.
    • Like x 4
  7. Joshan
    Joshan Member
    Chicago
    not scared, just have had no reason. Even when I made a 1k mile trip it would not have made the journey any less stops so was no reason.
    Edit: I mean from my house on the first leg. Never optimal to do that at a SC unless you like sitting a long time.
  8. coconutboy84
    coconutboy84 Member
    Ontario
    Oh no I get it. If you don’t need to. Then no reason to charge to 100. But I feel like some people avoid it like the plague lol. It won’t hurt it once in awhile. Just don’t let it sit at 100
  9. neptunesfinest
    NJ
    My Oct 2018 build AWD only charges to 295 @100%. :(
  10. Occar
    Occar Member
    TN
    The most resent Tesla app will tell you what your current 100% estimate is if you go to the charging screen and pull the limit over to 100% now (don't lift your finger, the estimate shows while you are moving the line). I guess it might vary a mile or two from what it would actually estimate if you 100% charged, but my LR RWD 100% charges to 322 and if I pull it over that's what it also estimates.
    • Informative x 3
  11. RFernatt
    RFernatt Solar/EV Owner/Enthusiast
    Eastern Panhandle, West Virginia
    My Sep '18 AWD is about the same with just under 13K miles.
  12. Stellavator
    Stellavator Member
    NC
    Fudge you guys...
    I'm getting 290...
  13. Wvapoker
    Wvapoker Member
    Charleston, WV
    I have a 2019 M3 LR Dual Motor running 36.2.1. When I charge to 90% I only see 278 (279 is 90% of 310). The 322 is an EPA rating of the 2020 model. I don't actual think we will see 322 on the 2019 and prior models. But I hope somebody proves me wrong.
    After driving the car for more than two months I've determined that the rated range is pointless because your Wh/mile makes that vary so drastically.
  14. MagnusMako
    MagnusMako Member
    Austin, TX
    18k miles here. I used to get 310 or a mile or two under it. I supercharged the other day and it only went to 290 at 100% and kept saying 'Calculating'. I guess calibration must be way off but 20 miles less from the rated 310 or now 322 seems exceptional.
  15. jfrieden
    jfrieden Member
    Ashburn, VA
    I'm August '18. Getting 290. It's not enough to be a problem yet, but getting pretty close to a warranty claim if it keeps dropping.
  16. AlanSubie4Life
    AlanSubie4Life Efficiency Obsessed Member
    San Diego
    Interesting! First report I noticed here. Can you measure your discharge “constant” at some point? Requires a decent length drive or high consumption drive to be accurate but I wonder what it is. Just divide your Wh used (not what is displayed because of rounding - multiply Wh/mi * mi traveled) by your rated miles used for a single continuous drive.
    I would guess 221-225Wh/rmi, but I really have no idea. Maybe the battery is just higher capacity but that seems unlikely.
    Previously of course the constant was in the range of 230-234Wh/rmi.
  17. mmurphy
    mmurphy Member
    New Hampshire
    I have a 2020 LR AWD built end of Oct and I’m at 310. Haven’t seen the 322
    • Informative x 2
  18. mbdionio
    mbdionio Member
    Austin, TX
    mine is at 300mi with 100% SOC.
  19. texas_star_TM3
    Texas
    290 miles over 310 miles is a degradation of (6.5%) ...what warranty claim is that? you would need (30%)+ degradation to make a claim... that would be just under 220 miles of fully charged
  20. texas_star_TM3
    Texas
    300 miles here at 100% SOC. July '19 build with 5k miles on it.
