Just got the update on my 2020 AWD. I showed 198miles before the update and 203 after. Here are some captures. I didn't get a before from the app, but it showed 307 at 100%
Unfortunately you did not capture the rated miles, but I will assume ~70% SoC, or 226 rated miles (we know it ends in 6 and I know roughly what the answer should be...):
So, assuming that is correct, it does look like the 2020 Performance 18" constant has been lowered, exactly as expected.
Previously we were seeing a 247Wh/rmi constant with 314 rated miles at a full charge. (247Wh/rmi*314rmi = 77.55kWh)
Now they have adjusted to:
366Wh/mi*149mi/226 rated miles = 241Wh/rmi
So, 322rmi*241Wh/rmi = 77.6kWh (about the same quantity).
So all is well. Assuming I'm right about that 226 rated miles!
This is basically exactly what I would have expected from this vehicle based on the EPA results.
I expect the constant for the Performance Stealth 19" to be: 255Wh/rmi
And the constant for the Performance 20" to be: 260Wh/rmi
(This can easily be determined by changing your wheel configuration and recapturing this picture, capturing all three numbers.)
confirmed 18 - 241, 19 - 255 and 20 - 260 on my car
I saw 322 yesterday for 100%. Today, I saw it was at 321. But, note the bracket for trip is now more than 80%.
I have Dec '19 build. You will get 322 depending on how you charge. I see it when I top off at home with 110. If it is warm outside, I see it using level 2 charger. Never tried 100% SOC at supercharger.
My 2020 P3D- has received the update, but the charging screen on my app still shows 310 miles @ 100% charge. Is anyone else seeing this?
2018 AWD and I’m at 283mi apparently.2018 AWD current top shows 286 been as low as 282.
323 at 100% at 50F
Did the math several times on my drive home, and got anywhere from 241-243. SOC was between 70-75%. So I guess it has been updated. At one point, with the batteries warm, the charge slider estimated 313 miles @ 100%, so I guess it is updated. It had been a while since I checked before the update, so I'm not sure what it was showing before.You'd have to do the described procedure to make sure your constant has been updated to 241Wh/rmi. What were you at at 100% before the update? If it was lower - 302 to 303 rated miles, you simply have BMS perceived capacity loss.
