Anyone Notice Navigation Insists on Local Charging?
Discussion in 'Model S: User Interface' started by LLWS, Jul 27, 2015.
  1. LLWS
    LLWS Member
    Woodbridge, VA
    I live exactly 5.2 miles from the closest SuC in Woodbridge, Va. It seems that 50% of the time the car prefers to begin the trip by stopping by the local SuC regardless of SOC. Over the weekend, I figured I'd indulge the Nav system. It said I needed to go to the Woodbridge SuC for 0 minutes - and I did. I plugged into the SuC and was instantly ready to go. Failure to comply means the Nav system will attempt to get me to turn around desperately for 8-15 miles into each roadtrip requiring SuC stops when leaving my house (annoying), but I'll get over it for now.
    More interestingly, I cannot plan a trip home without it routing to the local SuC regardless of the estimated SOC at the final destination (my house). My workaround for routing home is to simply delete charging stops from the trip screen when I'm at my last SuC stop before coming home. For example, coming from NYC to VA this weekend, I routed to my home, and then at the Newark, DE SuC I deleted all charging stops which resolves the issue. Otherwise, I'm going to the local SuC! All this makes very little sense.
    If Tesla wants to discourage local charging, perhaps they should configure the Nav system to stop routing people who live close to the SuC to the local SuC on every trip? Just a thought.
  2. Majerus
    Majerus Member
    Illinois
    The trip planner stuff is beta, and needs a bit of work. I am sure its going to be fine in the next few releases. There are multiple posts on it doing some crazy things with routing, your not alone. O to get past the charging stops.. press the "trip" button at the bottom of the directions, it will flip the menu.. then press "remove all charging stops"
  3. wayner
    wayner Active Member
    Toronto
    Gives you a quick out if Elon is dissing you for using a local SuperCharger - you can say I was just following orders.
  4. liuping
    liuping Active Member
    San Diego
    "a bit of work", yes that all it needs :)
    Heck even the normal, no-changing-required route planning needs work. It's route yesterday for me was 30 minutes longer than Apple or Google maps. It wanted to use a route that was almost 2 hours, vs an hour and 20 minutes for everyone else. I never trust it for any complex routes...
  5. LLWS
    LLWS Member
    Woodbridge, VA
    The thought had crossed my mind...
  6. mibaro2
    mibaro2 Member
    Georgetown, ON
    It knows you like driving your Tesla and wanted to give you more time with it! :biggrin:
    OTOH, it needs some serious work. It has so many bugs that I am not sure where to start.
  7. LLWS
    LLWS Member
    Woodbridge, VA
    If I could just delete a particular stop, I'd be happy with such an option. Say I could just delete one SuC on the proposed route - problem solved. It's actually somewhat annoying, because I can't plan a trip leaving my house to say Florida without it routing to my local SuC. The consequence of this is I can't see how much charge I need to make the first real stop in say Glen Allen, VA. What I have to do is route to the Glen Allen SuC, delete all chargers and then see if I have adequate SOC to make that hop. If I could just delete my local SuC, I would, and then I could use the Nav system as intended.
    Maybe in v7.0, I guess...
  8. Majerus
    Majerus Member
    Illinois
    Delete the charge stops, then add them in manually.
  9. RAW84
    RAW84 Member
    Boston
    Yes, it's definitely screwy.
    I was leaving a supercharger in Milford CT heading north, and navigated to the next supercharger on I-95 which is in Rhode Island. I was at 174 rated miles, instead of just sending me up the interstate for 90 miles, or so, it wanted me to backtrack to the Greenwich CT supercharger first for some reason.
  10. LetsGoFast
    LetsGoFast Active Member
    Virginia
    If you know how to charge stops without erasing your current destination, especially if you can add "stops" plural, please share. That would be awesome.
  11. LLWS
    LLWS Member
    Woodbridge, VA
    Can you post a video of that process? I'm not sure it's possible. What would be great is a little "X" to the right of the SuC stops when you press the trip button to see all the chargers selected for the route. Bonus: Show the percentage of charge remaining estimate for the following stop assuming you skipped the next available stop. With that solution, I'd know whether or not I should hit the "X" and skip a SuC on my route.
  12. beeeerock
    beeeerock Active Member
    Kamloops BC Canada
    #12 beeeerock, Jul 27, 2015
    Nomination for 2015 Understatement of the Year Award!
    :biggrin:
  13. Vger
    Vger Active Member
    Salt Spring Island, BC, Canada
    Agreed! Having done many 1,000's of kms of road trips using v6.2, I am amazed that Tesla shipped this at all. Clearly it was rushed out for the "end of range anxiety" announcement, which was quite premature.
    I find it hard to believe that this bug could be that hard to fix. I certainly hope this behaviour, and the related behaviour of wanting to turn you around to the PREVIOUS supercharger, seemingly if you are predicted to arrive at the NEXT stop with any less than 20% SOC, is completely quashed in v7.0.
    This is really an embarrassment to Tesla, IMHO.
