hugh_jassol
right so 2A @ 5V = 10WI did these measurement myself a year back and was never able to repeat the 2A draw claim.
Not an expert by no means. I think I was seeing this myself when the PI was not connected to the internet. Attempt to ping from your computer to see if the PI is on the network. Run a ifconfig to see if there is a lan ip address assigned. If no on both. go back to your config file and ensure your ssid and password were set up correctly.I'm not having much luck with the setup of the Pi.
The installation stalls - here's the log file.
at 15 Jun 22:27:31 BST 2019 : Detecting whether to update wpa_supplicant.conf
Sat 15 Jun 22:27:31 BST 2019 : Wifi variables specified, and no /boot/WIFI_ENABLED. Building wpa_supplicant.conf.
Sat 15 Jun 22:27:31 BST 2019 : Rebooting...
Sat 15 Jun 22:28:17 BST 2019 : Detecting whether to update wpa_supplicant.conf
Sat 15 Jun 22:28:17 BST 2019 : Grabbing main setup file.
Sat 15 Jun 22:28:18 BST 2019 : get_script failed, retrying
Sat 15 Jun 22:28:21 BST 2019 : get_script failed, retrying
Sat 15 Jun 22:28:24 BST 2019 : get_script failed, retrying
Any help appreciated
Please post your configuration file, so we can look at what you've put in.I'm not having much luck with the setup of the Pi.
Do you have any weird (non alphanumeric) characters / symbols in your wifi password?Thanks for your responses.
For some reason, the wifi password is not being populated into the supplicant.conf (the SSID is there)
I'm going to put it in the corner for a week and then come back to it.
It will prevent the damn thing going out the window!
Are you using a Pi Zero or another version of the Pi? If you have Sentry Mode enabled, the USB should stay powered and not cause a reboot. If you're using a non-Zero Pi, then it might make sense to connect directly to the DC 12v, but that requires you to go through a HAT or the GPIO pins on the Pi.I've given up on trying to make this work. It appears as though my Tesla cycles the USB power when it doesn't detect any device connected, this causes a reboot loop.
The only work around I've found is to connect the Power Only USB port on the Pi, wait for it to finish boot-up, then also connect the Data+Power USB port as well, taking up both USB ports on my car.
This just isn't set and forget and would require me to do this every time I get in my car.
Have sought advice online, but most responses are "yeah, we've seen this", with no help offered.
I'm using a Pi Zero, but I have sentry mode disabled at my house, which means when home, the USB port loses power and I have to manually do the reboot process every morning, not worth it.Are you using a Pi Zero or another version of the Pi? If you have Sentry Mode enabled, the USB should stay powered and not cause a reboot. If you're using a non-Zero Pi, then it might make sense to connect directly to the DC 12v, but that requires you to go through a HAT or the GPIO pins on the Pi.
Anyone have any luck setting this up with a QNAP NAS for the shared folder?
I've just about reached the same conclusion. I've scaled back my project to see if I can even get the car to recognize the RPi 0 W as a USB drive. I was able to get the Pi to be recognized as a mass storage device when I plug it into a Windows, Linux or Chromebook computer. No problem accessing, creating, deleting or modifying files on the drive.I'm going to put it in the corner for a week and then come back to it.
See my previous posts. To make it work in my car, I have to connect the power only USB port, wait for it to finish it's boot process, then connect the Data+Power USB port tot he car to recognise the Raspberry Pi.Not sure y you need to 'manually' reboot, it automatically reboot when it is powered
