Anyone suffering from strain in their left leg?
Discussion in 'Roadster 2008-2012' started by Chillout, Sep 25, 2014.
Tags:
  1. Chillout
    Chillout Member
    the Netherlands
    Hi all,
    I've noticed that my left leg hurts after my daily drives, especially in the knee/outer lower leg. It might be because of my left foot leaning/pushing on the small edge of the deadpedal/footrest... Does anyone else have similar symptoms? I would love to exchange experiences and thoughts, before removing/replacing/enlarging the footrest.
    Thanks in advance!
  2. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    Rarely, do I have an issue even on long drives.
  3. Chickenlittle
    Chickenlittle Banned
    Virginia
    could also be from sciatica/lower back issue. the dermatone (area of distribution you are describing) is close to that too.
  4. Chillout
    Chillout Member
    the Netherlands
    That sounds plausible, thanks. Would I suffer from pain in my hip area with this as well?
    I drove a different car for 2 weeks, and I noticed my leg didn't hurt any more... that's where I made the connection between the car and pain.
  5. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    In this other car were you in such a low position as the roadster?
  6. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    A couple of years ago my back went out, and the only car I was comfortable in turned out to be the Roadster.
  7. NEWDL
    NEWDL R#350 R#1323 Sig23(traded) 8136, RWD LR 3, P3D
    NE OHIO
    I do have some pain in my ankle when I drive the roadsters. It is my own fault. I do not notice it, but for some reason I roll my ankle and rest my foot on its side when driving the roadster (on the carpet). It is the oddest thing and I have no explanation. :confused::rolleyes:
  8. Chickenlittle
    Virginia
    Don't practice medicine in forum but possible. See your doctor if it continues
  9. wycolo
    wycolo Active Member
    WA & WY
    Roadster offers alternative position: feet all the way back and up on the ledge just forward of seat, knees high. Must be in cruise control. Allows wrapping feet & legs in blanket to avoid frostbite, etc.
    Also one leg at a time can be put on up on dash, to reduce edema.
    Try these - good chance your pain will relocate!
  10. TOBASH
    TOBASH Supporting Member
    Rockaway Beach, New York
    I can just see the commercials at 3AM...
    "DO YOU HAVE A TESLA ROADSTER OR LOTUS ELISE AND SUFFER FROM BACK PAIN AND SCIATICA? IF SO, CONTACT THE LAW FIRM OF PAIN AND SWINDLE. OUR FIRM HAS HELPED VERY FEW CLIENTS, ALTHOUGH WE ENSURED THAT WE PROFITED FROM THEIR SUFFERING. THERE MAY BE LIMITED TIME TO ACT, AND DEADLINES ARE APPROACHING FAST. FILE NOW!"
    LOL
    Small cars are tight, especially if you are tall or "generously proportioned."
    This might be something to ask on the LOTUS forums. That being said, if you know the car is hurting you, maybe you should consider giving it up.
    Feel Better,
    T
  11. bart513
    bart513 Active Member
    East Hampton
    I have noticed for some time now that after 2 hours of my 3 hour commute the toes of my left foot start to hurt a bit. There is no numbness or tingling but perhaps as if they have been pushed to the side of the footwell for too long? I often do what wycolo says and put my left foot flat on the upper part of the floor with my knee up - typically when in cruise control mode:)
  12. Chickenlittle
    Virginia
    Just remember that orthopedic problems have existed long before tesla and roadsters. When I showed the car to a cousin he told me to remember to stay slim and limber
  13. Chillout
    Chillout Member
    the Netherlands
    I'm pretty slim and athletic, but I have to admit: I have a history of orthopedic **** ;)
    I will try to make the foot rest a bit wider, so my foot will rest at a straight angle, instead of leaning inward, because it's such a small edge.
  14. slcasner
    slcasner Active Member
    Sunnyvale, CA
    Yes, sometimes I find that my left foot hurts because I have been pushing too hard against the footrest, and since the footrest is narrow, the outer edge of it accentuates the pressure in the middle of the ball of the foot. My solution is to work on improving brain-foot communication.
  15. hcsharp
    hcsharp Active Member
    Vermont
    The Roadster is the most comfortable car I've ever sat in for long periods and I don't have a problem with my left leg. Having said that, there are times on long trips where I wished the dead pedal was wider. For me the seats and position are more comfortable than the Model S where I get small aches and pains after long periods. Not so for my wife. But the passenger seat is not as good. The firewall/footrest is too far in front of my feet.
  16. spaceballs
    spaceballs Member
    Sammamish
    Agreed, my biggest complaint about sitting comfort in the roadster.
  17. Andrew Wolfe
    Andrew Wolfe Roadster 472 - S 440
    Los Gatos, CA
    I don't have an explanation - but I do the same thing.
  18. wiztecy
    wiztecy Active Member
    #18 wiztecy, Sep 25, 2014
    I typically have my seat adjusted so when I extend my left leg its out and fully extended, my foot is almost flat with some wiggle room against the firewall.... no pressure at all, its like and laying on a bed. I'm thinking of removing the stupid mini foot rest / dead pedal that's on the left driver's side. I never use it and when I do it puts pressure in the wrong places, knee, hip, etc. when I do use it. I'd rather have more side to side leg room.
    Also getting in and out, if done wrong, will put lots of stress and strain on your muscles and joints. Ensure you've perfected the entry/exit of the Roadster first, then adjust your seat/leg area.
    Everybody's different, so what works for one may not work for all.
  19. ekotysh
    ekotysh RoadStar #502
    Sausalito, CA
    Have to agree with Doug, I too had my back go out recently and I feel the most comfortable in my roadster. Went to Napa recently and it didn't bother me at all on a long trip
  20. dsm363
    Nevada
    Is it a height thing? I find the Roadster seats uncomfortable on long trips but I'm over 6 feet tall.
