I can understand affordability if that is a personal issue, but beyond that the Model Y is the simplest car to drive and operate that I have ever had in the 64 years that I have been driving. Once you go through the simple setup menu to create your profile everything is simple and/or automatic. You walk up to the locked car, open the door (enjoy easy entry), get in, put your foot on the brake, everything moves to your settings, select D or R and drive away, no need to even use the brakes again except for rapid stop. Charging is simple, just plug it in at home or at a Supercharger. Everything else is icing on the cake, learn what you like at leisure.
Why go halfway to an electric car when the best is designed from the ground up for efficiency, aerodynamics and the best technology, available as you need or want it.
Price? Audi Q3 or VW Tiguan, both small SUVs, but the Q3 is worth it if you can afford it.
