Here in California, at least, residential customers are fed from a single phase distribution system. A typical single family home residential transformer has a 12kV primary input and a 240v output between the two outside legs with a center tap that is used as a neutral. Between the two hot wires there is 240 volts and either hot wire to neutral measures 120v.It requires the home owner to find two 5-15 outlets that are on different breakers and also on the opposite phase. Possible, but tricky.
North American have a two phase supply (the grid uses 3), so that houses can have 240v by combining two phases, and regular 120v outlets by having one or the other phase.
If you want to have a lower amperage outlet, have an electrician install a 6-20 (welder) outlet for you. (240v 20a)
Benefits of lower amperage are a thinner wire easier to pull through walls and it takes less from your breaker box.
I personally found the Quick 220 to be very useful at my cottage, having an electrical panel that simply cannot accept an additional 240 volt breaker as it has reached full capacity and would ultimately involve the purchase and installation of an entirely new panel at a cost of several thousands of dollars!I recently came across this product. You plug it in to two regular 120V 5-15 outlets and it converts to 220V outlet (basically the equivalent of a 6-15). Has anyone used this and did it affect anything in your home?
