I went to my normal mechanic to get 4 tires mounted and balanced and he didn't want to do it. Said he didn't have the right tools. Is there something special about installing tires on a Model S or is he being goofy?
Thanks!
Thanks!
...goofy?...
Yes!
However, to prevent injuries and deaths, you need to make sure to disable air suspension first before lifting the car up because the suspension system might automatically try to level itself out and violently whack someone with those tires.
...whacked.
Additionally have the proper jack pads to protect the edge of the battery there. (small 2 x 4 piece works too)
Thanks!
Try jacking up your car, once the wheels are off the ground the car goes to "jack mode" all by itself. At least Nicki does. Even getting one wheel jacked off the ground sets "jack mode".Many Tesla have air suspension and it needs to be locked out (Jack mode)
Costco had the same attitude and Sears delayed working on the car till one of their experts was around (this was waaay back in 2013, so things might've changed by now). However America's Tire had no worries about it and have been great. They've got all the right tools and know how to work with the cars.I called another place (Firestone) and they said they wouldn't do it because the tires were "low profile" and they'd get scratched. I decided to just take it to Tesla. It'll be $50 more for the mount/balance but at least they should be able to do it right.....
Be sure to either buy a lug nut puller ($4 plastic 'tweezers') or be sure that your favorite tire shop has one, or some others method to gently and safely pull the covers.
isopropyl rubbing alcohol or go to any auto store and get wax and grease remover (its a white sprit) also know as prepsolHere's a related question -- how to clean the residue left by wheel weights after they have been removed? That crap is impossible to get off. I'm hoping there is some magic solution out there, like nail polish or something. Help!
