AP Braking when highway changes
Discussion in 'Model 3: Driving Dynamics' started by mreynolds767, Dec 27, 2019.
  1. mreynolds767
    mreynolds767 Member
    Boston
    While not a major issue, I would put this under more of a minor annoyance.
    Curious if an issue for others as well.
    A couple of areas I routinely drive; the highway I am on changes to another highway. There really is no turn off or similar so one does not lower their speed or anything similar in these examples.
    The car if in AP at say 75 will abruptly brake to 55 which can be a problem if a car is close behind ; as there is logical reason to brake here. Has to be something in the map telling the car of a speed limit / road change or something that is causing it.
    Main location is where Rt. 3 heading north ends and becomes Rt. 95 / 128 south of Boston.
    Any way to change the car's behavior in these commonly driven places?
  2. Knightshade
    Knightshade Well-Known Member
    NC
    Yeah the speed limit is based on map data. If the speed limit drops the car slows down. Worked as designed.
  3. mreynolds767
    mreynolds767 Member
    Boston
    While it makes sense it can be a dangerous situation.
    As in this case, it is a multiple lane highway with absolutely no reason to brake ; or I should say there may be a legal reason to drive slower but in practice zero cars brake here.
    Rough guess Rt. 3 is a 60 MPH zone and when it becomes 95/128 it is a 55 MPH
    If I had AP on 75 it should not go all the way down to 55 ; if it is going to reduce speed it should be to 70 (5 MPH less to match)
    That would at least not be dangerous.
  4. ewoodrick
    ewoodrick Well-Known Member
    Buford, GA
    It definitely sounds as if the speed limit is charging, or you are greatly exceeding the apees limit and the speed resets.
  5. mreynolds767
    mreynolds767 Member
    Boston
    Am positive the speed limit changes here but is a minor change.
    Goes from what is a 60 MPH or 65 MPH highway to a 55 MPH highway ; still the rate of travel/speed of the cars does not lower.
    And if I was previously exceeding the speed limit why does the change cause Telsa to reduce my speed to match the limit?
    This particular area often has traffic at all hours so not always going to be affected but the way the car currently reacts here is not like any human driver would and that is my point.
  6. ewoodrick
    Buford, GA
    The speed is going to set to the new speed plus the amount specified in the settings. If you have it set to +7 and you are in a 65 going 75, and then go into a 50, then the car will slow from 75 to 55.
  7. mreynolds767
    mreynolds767 Member
    Boston
    Ah thank you!
    I think I have that setting at 0 currently so if I change that to plus 15 that should be better for me
  8. TydalForce
    TydalForce Member
    West Chester, PA, USA
    It's kind of a murky area; on the one hand, you >technically< shouldn't be going so fast. On the other hand, the car shouldn't suddenly decelerate when it could do so more gradually.
    You might want to do a "Bug Report" next time it happens.
  9. mswlogo
    mswlogo Well-Known Member
    MA, NH
    I set my offset to -20 which kills the car from applying speed changes and greatly reduces phantom breaking.
