One does not need to be a layer to read a manual.It seems Exiom is a kind of Tesla’s lawyer..
Is it normal to have them in this forum ?
True, but reading the manual doesn't change human nature.One does not need to be a layer to read a manual.
You should try that, RTFM.
The same way the standard cruise control function on other cars saves you some energy by allowing you to not constantly exert force on the accelerator pedal, AP1 (and AP2, currently) saves you some energy by allowing you to not constantly exert force on the steering wheel. However you still must keep your hands on the steering wheel so that you can respond quickly if something goes wrong, the same way you must keep your foot hovering on the brake pedal with normal cruise control so that you can respond quickly if something goes wrong.If I report my experience is to inform other Tesla drivers that AP1 is not still safe and that very same attention as while driving manually is needed.
(and here comes my question, then what is the benefit of using AP ?)
I honestly believe that it is no excuse and it is not technology's fault that their user fail at common sense and using the technology anymore than as designed. Sure... sometimes technology functions better than presented and you push it further... but should anything go wrong... as the driver of the car... you are still responsible... you used it in a way you were told not to... so you willingly took the risk... thus Autopilot was in no way at fault nor dangerous.True, but reading the manual doesn't change human nature.
I read the manual a dozen times, and have 50,000kms of autopilot driving. I still have caught myself hitting a pothole I'm sure I'd have avoided if I'd been driving manually.
It's not an excuse, it's just reality.I honestly believe that it is no excuse and it is not technology's fault that their user fail at common sense and using the technology anymore than as designed. Sure... sometimes technology functions better than presented and you push it further... but should anything go wrong... as the driver of the car... you are still responsible... you used it in a way you were told not to... so you willingly took the risk... thus Autopilot was in no way at fault nor dangerous.
I do very much agree Autopilot needs to get better... it needs to get better because it does not yet drive better or as good as humans... NOT because humans are irresponsible and fail at complying with instructions or driving. The cause for it to get better is not to compensate the failure of its drivers and to relieve them of responsibilities. So while the ultimate goal is for the cars to drive itself... but the rush for it to get better should not be because people cannot be responsible with using in-progress technology which all owners are fully aware (there really is no excuse why you are not aware) that it does not function the way you dream it to. At every stage of enabling it... it tells you it's limitations.
So what I am most bothered with is that the OP's complaint about "What AP is for if it can't drive itself with a less attentive driver?" At no point in time it was conveyed that AP is capable of doing so, AP is a name given to the umbrella of systems, I think it is a bad name as it gives people like the OP the false impression that it indeed auto pilots itself, even then, like I said before even in an aircraft with autopilot... it doesn't mean the pilot can be any less attentive. It is a technology which makes the operator more comfortable.
The final thing that bothers me the most is that the OP tries to lay blame to AP somehow being dangerous when operated outside of its design parameters (with a less attentive driver). He also states that because no party was fined, that somehow he is not responsible for his own actions and his accident is caused by AP's failure to stop and not because he failed to drive.
This is exactly what I was going for.You have to pay attention all the time
