I don't have a sample myself for obvious reasons, but from what I see, once hw2.5 references appeared, additionally references to a dual node (not just gpu) setup have appeared as well at the same time, which does not sound like it's just a pure coincidence to me.So, by this information, those with AP2 but not AP2+ hardware are going to need a hardware upgrade? ugh..... Is AP2+ the dual GPU that you spoke about in a different thread @verygreen ?
it's some sort of a gps related thingy I believe.@verygreen did you come to a definite conclusion about what lb is?
I don't have the full Model 3 setup, only a partial view via some of the shared code on ape (and some other bits elsewhere).Could AP2.5 refer to some new setup/separation of hardware in the dash? Not necessarily (just) a new AP2 computer...
I.e. the rumored new architecture that runs the horizontal screen and possible future HUD? I.e. AP2 suite without the legacy Tegra 2 and S/X screens?
There's no sharing duties between CID and ape. CID displays stuff relayed by other parts of the car and sends control commands from user input (like pressing stuff on toucscreen to change suspension height or headlghts, or A/C controls).OK. Good info.
Could there be differences in interfacing or sharing duties with the new CID compared to the old?
I am trying to get a sense of if this AP2.5 is a new APE box coming to current S/X dash too or if it is part of a completely new architecture inside the new dash that also depends on other new parts...
Or are you perhaps suggesting the AP2.5 has even new sensors?
sensors are external to APE, but the code that inits them is mostly the same (but not exactly).I get that @verygreen. I was more trying to understand if AP2.5 is also a different architecture regarding other components or if it is just a new APE box only with 100% the same connectors and sensors etc. as AP2.
Is AP2.5 a plug and play replacement only for AP2 APE or is it more?
Model 3 has a different connection backup camera obviously, but even for non model 3 HW2.5 backup camera is connected differently.
I don't have the physical device and the code for ape we have does not contain all of the hw2.5 components, as such I don't know if it's really a drop-in replacement or not, but given the pictures we saw of somebody's desk with a presumably hw2.5 device, it looks to be a drop-in replacement.
Don't see anything readily apparent about this, but the camera init code is getting bigger and I don't feel like going through all of it.Interesting... I just noticed that the side repeater cameras have been revised recently.
From Oct. '16 until around May/June '17 (Model X):
1034345-99-A
July '17 (Model X):
1034345-20-B
"Korea use only 20-B or newer, for other countries ok to use 01-B or newer".
@verygreen do you see any traces of this in the SW?
Part of that is the different model 3 code, but that's mostly a turn off switch, so the rest must be for the other cases.
the cars are displayed by ic on signal from ap.Are you able to evaluate the code against any upcoming features that aren't currently enabled? (I.e. Additional cameras, vehicles displayed on CID, intelligent lane changes, etc?)
Any other interesting tidbits in recent releases other than mention of model 3 or ap2.5?
