No reasons to worry. I just mean that the actual ARM cpus are as underpowered as ever, running gzip -1 on the raw image dump takes ~1.5 seconds (including the startup time) so we cannot use it for any sort of heavy lifting like that, esp if e compete with other tasks for cpu time. I am sure Pascal stuff is powerful and all that, but we cannot really use it for our purposes because autopilot is using it already and it's not like a general purpose cpu.
The cpufreq IS correct. in /proc/cpuinfo I now see that cpus 1 and 2 are different from 0, 3-5.Do you have any control over whether you run on the Cortex-A57 cores or the Denver? The A57 core is extremely extremely simplistic and weak. It's designed to be the little cores in ARM's AMP design. I'd expect the Denver cores to be as fast as a 4 year old desktop processor. But based off how the comments refer to them as the "vision" cores, I'd imagine they've set up cgroups or some other affinity mechanism so that the A57's are what you're using for random background tasks like poking around at the shell.
P.S. The commented out cpufreq hacks seem wrong/historical…. The boot spew seems to show 6 cores, with the A57's detected first.
The firmware image is a VERY stripped down linux rootfs, consisting mostly of busybox (+ all the autopilot thingies + some other related stuff + surprisingly full alsa setup (autopilot plans to output to audio? or access microphones? or both?))
It does not appear to be based on ubuntu or anything else I recognize readily.
Has custom looking init stuff with custom looking logging infrastructure (sv, svlog - rings any bells?)
Kernel is "3.18.21-rt19"
6 arm64 cpu cores ("Cortex A57") + the Pascal GPU.
/proc/cpuinfo is really unspecial.
They have sshd, but it's "locked down" to only accept key auth (root has public ssh rsa key embedded, no signs of private key anywhere, perhaps somewhere at the mothership?)
The initial lockdown is done on te first boot (triggered by the cid).
There's still this matter of the mystery "lb" device.
Are the SoCs on a dual setup represented as two different nodes? Could lb be the other part of it that's just off for now?
BTW, HW2 systems added 2 more computer systems (As in network-accessible) compared to HW1, one is eap itself, the other one is cryptically labeled lb, but I have no idea what is it and when is it on if ever.
Yeah, that Gig-E link does indicate that A and B parts may be separate.Anyway important parts - for lb I only know the name and adress, but it's not on ever as far as I can tell.
the diagram noting A-B link is gige seems to imply B host is a separate node, so a high candidate for this LB stuff.
EAP node is actually called ape.
Regarding the name ape, AutoPilot Ecu perhaps?
trafficlightstop scene:View attachment 226429
This example might explain why AP2 doesn't assign cars to adjacent lanes yet on the UI. It looks like only the fisheye lens's view is appropriate for that purpose.
The front fisheye isn't supposed to be part of eAP, only FSDC (according to the original description emails that named the cameras used specifically.)
The wider conventional front camera should be a close match to the AP1 camera - and AP1 doesn't put cars on the driver's display until they hit about the 45 degree line from the camera/radar (but it also won't change lanes into them - probably from ultrasound?)
Curious: How are you confirming this?Not quite I can confirm that ap2 main camera fov is the same. It's just that tesla is still way behind eyeq3
Field observation: When we opened to have a look at the ECU (car in P), the graphic card fans were running initially. After a while, however, they turned offAPE is only on if the car is not locked or if you are driving.
It shutdowns when in park for too long as well.
