AP2 Ultrasonic Sensors - Are they actually longer range than AP1?
Discussion in 'Model S' started by ab26, Jan 28, 2017.
Tags:
  1. ab26
    ab26 Member
    Bay Area, CA
    I have owned both an AP1 and AP2 cars. Having driven my AP2 car for about a month, I am starting to suspect whether the ultrasonic sensors are really longer range than AP1. Several of my unscientific observations indicate that the range is similar to that of AP1. Unless, they need to update software to make it longer range. Which brings me to another question, whether they are actually different hardware (irrespective of what Tesla claims), and are they getting a longer range by a FW update since it might be an algorithm change that could enable longer range?
  2. lunitiks
    lunitiks ˭ ˭ ʽʽʽʽʽʽʽʽʽ ʭ ʼʼʼʼʼʼʼʼʼ ˭ ˭
    Prawn Island, VC
    Very interesting. Please elaborate what makes you suspicious about this
  3. kdday
    kdday Member
    AZ
    I have had the same thoughts. The ultrasonic sensors provide the same ~8feet of distance in my non-scientific tests on my AP2 car and seem to act identically to how the AP1 car was during my test drive(s).
    I honestly can't tell a difference and frankly they're worthless.
  4. Hammer@OR.US
    Wren, Oregon
    I dont think there is anyway to tell by the user interface. Just as in the HW1 the user interface doesn't display the full range of the sensors, neither does the HW2. The control system is getting data from the sensors at their full range it's just that the software designers have only chosen to show you the data within a certain range.
  5. ab26
    ab26 Member
    Bay Area, CA
    Well, just driving on my usual route from work to home. There's a section where I am driving against a wall. Depending on how close I drive to the wall, I can see the sensor lights come on / off on my dashboard. I don't see any difference comparing my AP2 car to AP1.
    Now, it can be very well true that the its not just shown on the dashboard but the actual sensor output is different. But knowing how Elon goes overboard with his marketing, I think otherwise.
  6. chillaban
    chillaban Active Member
    Bay Area
    I'm not at all convinced that the rear corner sensors aren't showing their maximum range. Auto Lane Change seems more than happy to initiate with someone right beside me but offset in their lane a foot beyond the range of the rear whiskers.
  7. lunitiks
    Prawn Island, VC
  8. bswn1
    bswn1 Member
    I have had both. The new sensors are definitely farther range and more sensitive. No question in my mind.
    The arcs even extend beyond what my AP1 car rendered.
  9. lunitiks
    Prawn Island, VC
    I wonder what makes them "farther range".
    I mean, it's butt old tech. Ultrasound. Sending, receiving and timing.
    Must be higher sensitivity on the receivers, combined with more sophisticated interpretation of the echo signal. Would be really nice to hear from some experts (chime in!)
  10. ab26
    ab26 Member
    Bay Area, CA
    Can you share a screenshot of your dashboard which indicates farther range?
  11. ab26
    ab26 Member
    Bay Area, CA
    For larger range, these are the few things that are important. Higher sensitivity on the receivers, higher transmit power on the transmitter, attenuation of the ultrasound in air and the frequency of operation.
    It is unclear how some of these are different from Ap1 to Ap2.
  12. bswn1
    bswn1 Member
    The first update that was pushed to cars in Nov / Dec that activated the Ultra-sonic sensors included a perfect screenshot showing the extended arc. Feel free to Google it.
  13. ab26
    ab26 Member
    Bay Area, CA
    Yes. I know which arc you are referring to. But in my unscientific tests, I have never seen that arc appear on my dashboard. I am curious if other's have seen that.
  14. bswn1
    bswn1 Member
    Yep I see it regularly!
  15. ab26
    ab26 Member
    Bay Area, CA
    Screenshot please?
  16. zambono
    zambono Active Member
    DC
    I am on 22 HW1 and I have noticed the ultrasonics are either more sensitive or what is being displayed is now further out. What used to be a white is now yellow etc.
  17. lunitiks
    Prawn Island, VC
    I noticed this too, but was afraid I'm delusional. But when did this happen? With the orig 8.0 release or later?
  18. zambono
    DC
    As far as I am concerned it just happened with 22
