App: Climate turns itself off a few seconds after I turn it on....
Discussion in 'Model S: User Interface' started by Soundchasr, Dec 14, 2016.
  1. Soundchasr
    Soundchasr Member
    Very close
    It seems just about every time I turn on the heat/AC with the Android app it turns itself off after a few seconds. If I turn it back on again it stays on. Anyone else have this problem and know a fix?
    Thanks.
  2. ba2002
    ba2002 Member
    US
    Mine behaves the same way 75% of the time. Rest of the time it works on the first try. ::shrug::
  3. Philgrover
    Philgrover Member
    Loughborough
    I think it is probably just overlapping messages. The app fetches the car status in the background. If you turn the heat on too quickly, the status message you get is the old one and out of date. If you then wait 30s or so, you'll get another update with the heat turned on. The heat will have turned on when you pressed the button. That seems to be how mine behaves anyway.
  4. bredi
    bredi Member
    San Francisco
    this can be dangerous with dogs in the car. I have to remind my wife and myself to check again to make sure its active.
    I also wish there would be a time limit you can set or remove. And a notification that it will turn off soon.
