App keeps changing setting to range charge?
ajw
84
0
Richmond, VA
Anyone else had this problem? Each time I log in to the app...it warns me to switch off of range charge. Each time I make this change, no problem. I check the console in the car and charging % looks as expected. I then check the app, and it again warns me to switch from range mode....and restarts charging the car...until I again, switch back to standard charge.
so the app appears to be 'stuck' on having me at range mode every time I log in.
andrewket
5,704
1,525
Nope, that's weird.
Seven7
524
143
Sarasota, Florida
Close out the app and reboot your phone, I have no idea if that will work but it's worth a shot. Might try unplugging your car while the phone reboots.
N4HHE
706
55
Madison, AL
Since 5.9 I keep noticing from the car's console that its apparently set to charge at 40A. It doesn't have problems remembering to start at 2:00 AM.
Friday I left the Model S at home. Then from work decided I needed a full range charge for after work. From the iPhone app it charged at 26A, and I was happy.
jerry33
Mar 8, 2012
19,529
21,748
Texas
There's a bug in the software that has the display show 40 amps. If you actually watch while it charges, it uses the number that you set, and you don't have to change it.
