SageBrush
REJECT Fascism
Clearly you are unfamiliar with the greenhouse effect. Who knows, this experience might teach you a little bit that you should understand about AGW/Climate Change.This is clearly not correct
Just picked up model 3 today -- the interior temp on the app is reporting over 110 degrees the outside temp is 60 degrees.( car is parked) This is clearly not correct. Has anyone had this? I am going to try a hard reboot tonight. Maybe I have a bad sensor but when the climate is on it seems correct. My concern is I don't want the incorrect reading to cause the car to cool itself all day and draw down the battery. Any insight?
Cabin overheat protection has a “no a/c” option. Not sure what this does, but I wonder if it cracks the windows and runs the fan without a/c?Im not an owner yet, so the question is can you roll down the window with the app instead of turning on AC?
Even more spiffy is an infra-red thermometer. They are not expensive.One great way to do it, as others have mentioned, is to get you a digital thermometer and keep it in the car.
I doubt the window opening. Running the fan though will work well in conjunction with a sun-shade.Cabin overheat protection has a “no a/c” option. Not sure what this does, but I wonder if it cracks the windows and runs the fan without a/c?
Adding a film is going to be really important to the Model 3Early on someone said the interior temp was inaccurate as the temps got really hot so I took a home hygrometer/thermometer and compared temps.
They were very close in value through the whole range that I measured. Hottest I measured was 115 but I'm fully tinted with shades on the windshield and pano.
Those usually only measure surface temp, IIRC.
A normal thermometer will measure air temp!
If you have a black dashboard in the sun, if you touch it, it will be hotter than the surrounding air!
Yes, IR thermometers measure surface temp. A surface that is in the shade will equilibrate to ambient; that is independent of color.Those usually only measure surface temp, IIRC.
I'm curious, is this with aftermarket window film or is that stock?
These temps are not unusual for Oklahoma in the summer. I have film on the front and rear doors, but not the front or back. The tint on the top glass is beyond good, so most of the heat is coming in through the front window.
One of the earlier software versions I had, had overheat protection in a hidden menu. I couldn't say for sure, but it seemed like it may have also been motion/heat activated.
As I remember, you had to push the brake and and passenger airbag icon as the same time, and it brought up an extra menu.Yeah, I get Tulsa's not that far North of here. Reason I asked was because I'm definitely putting film on the sides & back and was wondering what the baseline was. The rear window is pretty big and quite horizontal so, even with the partial factory tint, it'll really soak the noon-ish sun up. For the same reason I'm going to try get the windshield done, too, with a 90% (basically no tint, just heat block) once I get solid confirmation that's legal here in TX (pretty sure it is).
Oh? I had not heard about that.
I use two of the 'twist to fold' somewhat rounded standard size shades. They work fine, although I do have to release the sun visor to bring it down low enough to pin the shades.Can you suggest an option for a windshield shade that works well with the Model 3? I've tried a few that I had purchased from Autozone for previous cars. Even the largest one I have that works great on the pickup didn't work on the Model 3 with its large windshield and the tiny sun visors.
