You can press the stalk down instead of up to shift into neutral. Then there is no danger of accidentally selecting reverse, no matter the speed.
Careful here! There is something speed sensitive to be aware of:
If you are moving forward in Drive
at slow speeds (think parking lot crawls) and you whack the direction selector switch all the way to Reverse... the car
*does* go into Reverse but you will still be rolling forward. When you press the go pedal, your direction of travel changes abruptly and you're now going backwards. And vise versa, slow Reverse to Drive and it will go into Drive your next power application will change you to a forward direction.
Above a certain speed, this is no longer true. For example at highway speed, you can whack the selector all the other way from Drive to Reverse (in one go) and the car does not select that direction. It picks Neutral.
People Know your Direction Selector!
Pop quiz: without checking the car but just your memory... How may detent positions will you find on the "gear" selector, as you move it through its whole range? And where are the Drive and Reverse positions located, up or down.
Pick one answer:
2 positions - the car is in Drive or Reverse at all times. Stalk stays up for Drive (normal resting position), bumps down for Reverse.
2 positions - the car is in Drive or Reverse at all times. Stalk stays down for Drive (normal resting position), bumps up for Reverse.
3 positions - the switch is always resting in a middle position with one bump up for Drive and one bump down for Reverse. If you bump the opposite direction you're going, you get Neutral.
3 positions - the switch is always resting in a middle position with one bump down for Drive and one bump up for Reverse. If you bump the opposite direction you're going, you get Neutral.
5 positions - the switch rests in a middle position (Neutral) with one bump up or down also gives Neutral (from whatever gear you happen to be in) or two bumps up for Drive, or two bumps down for Reverse.
5 positions - the switch rests in a middle position (Neutral) with one bump up or down also gives Neutral (from whatever gear you happen to be in) or two bumps down for Drive, or two bumps up for Reverse
So you think you know your Tesla, huh? Now go check the car!
Surprised!?
Or did you get it right?
