Do Tesla approved electricians charge more? Probably yes.
6AWG is definitely too small for a 100A subpanel.
2AWG THHN copper conductors pulled through buried conduit would be ideal. The ground conductor only needs to be 6AWG I think (double-check this) It gets you to a full 100A panel (100A breaker in your main panel). Aluminum #2 SER cable is common and pretty cheap, but can only carry 90A (90A breaker in your main panel).
Other considerations:
Run buried PVC conduit out to the garage for a clean look instead of overhead wires.
Drop in some extra 1" conduit runs with your power run so you can pull other lines out to the garage in the future. I installed 2 extra, empty conduit runs with pull strings. I'll probably run ethernet in one and a 3-way switch for garage exterior lights to the house in the other.
I'm waiting for another quote and I'll let you know.Hey Mymeatguy - Let me know what you end up doing, I'm also in Ottawa.
I wasn't going to move on anything until I was able to configure the AWD version.
For occasional use sure, but if you are setting up your high frequency use home charge station, and do not want to wear out your 14-50 socket taking the UMC with you, and do not currently have a 14-50 installed, the HPWC is not unreasonable.
HPWC $500
UMC $300 + 14-50 Socket
HPWC also allows for load splitting if you are a 2 Tesla garage. 8 foot version is less cluttery for single spot garages.
After reading online reviews, I was comfortable with the lowest-price electrician. They did a great job - for the price, they also put wiring in the garage drywall and repainted my entire wall.
Moral of the story: Shop around.
I am in the process of getting quotes right now in Phx. Though I think I am going to use the cords supplied with the car.
Which electrician did you end up going with?
Do you mind giving out the name of your electrician?I'm in Ottawa and I had my Tesla HPWC installed in May. Cost me $852.00 including taxes, permit, and inspection. This included ~25' of #6 armoured cable and 60A breaker. I provided the Siemens 240V 60A 2 pole safety switch (from Home Depot $57) which is required by code. Here's a pic:
Not me mine is midnight silverWould like to know as well Kaoru!
As an aside, were you driving around Innovation Dr. the other day? I saw a black M3, first one I've seen in Ottawa, leaving the business park. Thought about following it like a creep.
No, that wasn't me as I'm mostly Ottawa South and around the Vanier area. During my delivery in Toronto, I met 6 people from Ottawa picking up their Model 3s. I've yet to see any of them which prompted me to join the Tesla Motors Club and the Ottawa Model 3 group. I'll be going to the meet up at Place d'Orleans on the 19th.Would like to know as well Kaoru!
There are a few costs:Has anyone looked at upgrading to a 200 amp service? Or do you think it will be fine with scheduling and 100 amp?
1. Field engineer inspection: complimentary
2. Engineering cost upfront deposit: 1000USD.
3. Aerial vs. underground.
3a. Aerial not explored and not applicable for me nor my friend who started this process
3b. Two paths: buried conduit or direct burial
3b1: A test mandrel is passed thru to see if the conduit is clear bore. Tree roots will trigger a conduit replacement. Size of conduit determines amperage.
3b2: The direct burial wire needs to be pulled up. This is the most costly as you may have to trench across your neighbors property to replace the wires all the way up to the .
3c: The work can be subcontracted to a 3rd party or one can simply use the power company at a higher cost.
4. Typically the service panel / meter will required to be changed out to match service 1:1. ~3000USD
I hope this sheds some light on a service upgrade.
