Are MX interior lights any better than MS lights?
Discussion in 'Model X: Interior & Exterior' started by skip8jj, Aug 17, 2017.
  1. skip8jj
    skip8jj Member
    Portland, OR
    The first mod we made to our MS was to replace the LED interior lights with the Abstract Ocean set. We have an MX on order and wonder if the Tesla is still using the weak LED interior lights? Thank you
  2. qadaemon
    qadaemon Member
    Sidney IL, Cape Canaveral FL
    Mine are the same as on the S from what I can tell. I guess I've never noticed them being a problem, but if you like the AO set on the S, it will probably be worth doing again on your X.
  3. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    About the first thing I did on ordering my X was to place the AO order. I've heard nothing about better lights being standard and I want to be able to use the frunk and other lights without pulling out a flashlight! :D
