Are the goodyear Eagle RS-A2 tires really that bad???
Discussion in 'Model S: Driving Dynamics' started by ljwobker, Apr 15, 2014.
  1. ljwobker
    ljwobker Geek.
    Raleigh, NC
    I'm having trouble with this... I know there are differences in tire performance to be sure... but the OEM Eagles are $500 for a set and the Michelin's are more than double that. For someone who doesn't drive particularly aggressively, is there any good reason not to go with the Eagle's?
  2. ElSupreme
    ElSupreme Model S 03182
    Atlanta, GA
    They aren't super awesome tires. But they seem to be pretty good. I am considering staying with them because they do seem inexpensive to some of the other options.
    They are a bit loud for my liking, and I think you could do a bit better for service life (mine are going to last ~35k-40k miles). And I am running them just past the wear strips.
  3. nrcooled
    nrcooled P#8946 VIN 03225
    NoVA
    I will have to say that I like them. So much so, that I bought another set with the rediculous deal that Tire Rack is running on them (~$500 shipped for 4). I don't need them yet since I only have 21k miles on the car but I have them for when I do need them.
  4. matbl
    matbl Member
    Sweden
    Where I am you can't even buy them from anywhere. That's how bad they are.
    But then again, you can't buy the Michelins either.
    On the other hand, all cars except Tesla are delivered with proper summer tires. Even french or korean compacts...
  5. ljwobker
    ljwobker Geek.
    Raleigh, NC
    Yeah, I'm not looking for whether they are strictly worse tires than the Michelins. I'm trying to figure out whether they are tolerable given that they're $500 less expensive for a set!!! ;-)
  6. howardc64
    howardc64 Member
    Seattle
    We've run them for 15k miles in Northwest's rainy weather and they seem fine. The tire+car's capabilities are pretty far beyond myself + wife's driving abilities :) Definitely like the RS-A2 price so will seek these for replacement when its time.
    I have gone highway speeds (70mph) in the pouring rain with with grooved (from studded tires) highway pavement. It doesn't inspire the greatest confidence so I find myself wanting to slow down a little for safety. I would probably do similar in my other cars/tire combination. Don't know if any other tires on the Model S would be better or not for this condition.
    Drove home fine in a freak snow storm while seeing a lot of BMWs unable to move. Model S's RWD fishtailed a little here and there compared to a FWD but not sure if anything related to the Goodyears.
    My evaluation is these tires and the car's capabilities are far beyond my usage :)
  7. Zextraterrestrial
    Humboldt/Los Altos
    I thought they worked pretty good. tried them on packed snow + fluff coming down @~45mph seemed fine. decent straight line acceleration but a little weak on cornering. but they are all-season. wet braking seemed pretty good too. for the price, awesome
  8. jerry33
    Texas
    The price is right.
    They seem to have lower rolling resistance than the Primacy MXM4.
    They have a tendency to skip across the road surface when turning. (The MXM4s just stick on the same corners.)
    They seem way more flat prone.
  9. JohnQ
    JohnQ Active Member
    Redding, CT
    17,000 miles in 12 months. No wear issues. Have replaced one that had a sidewall bubble from a stupid curb incident that also bent the rim a little bit otherwise no flats. A little concerned with standing water in lane ruts like @howardc64. Might look at other options but the price is ridiculously good.
  10. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    There tends to be a "you get what you pay for" factor with these things. But they're probably fine if you're not into high performance driving.
  11. mknox
    mknox Well-Known Member
    Toronto, ON
    I find them to be just fine. No issues at all.
  12. mnx
    mnx 2013 P85
    Ancaster, Canada
    Yup they are good for the price. I'm considering moving to a more sticky summer tire but only because I like to track my car...
  13. yobigd20
    yobigd20 Well-Known Member
    Skaneateles, NY
  14. kevincwelch
    kevincwelch Active Member
    Chicagoland
    I really think they are fine. Of course, you don't know what you don't know, so I might like some other tires much more if I had the opportunity to try them. I don't feel like they perform well in the snow; in fact, they're pretty terrible. However, during all other times of the year, I didn't have any problems. They seem to perform well. I do recommend getting winter tires if you're in a climate that has frequent snow. Hard to beat the price as others have noted.
  15. bob_p
    bob_p Active Member
    Looks like I'll need to replace my Goodyear 19s at the next service visit. Tesla's indicated they put another set of Goodyear's on the car - or I can switch to the Michelin's (Primacy?).
    Has anyone switched from Goodyear to Primacy on their Model S? And any recommendations for other owners?
  16. jerry33
    Texas
    Yes. I did. You give up a slight amount of Wh/mile for much better grip on the road. I got mine at Discount Tire where there was a $70 rebate and road hazard.
    Best advice for any tire: Keep some air in them.
  17. SFOTurtle
    SFOTurtle Active Member
    Los Altos, CA
    I have 17.5k but my SC said that the rears (I've had the tires rotated every 6k miles) were getting close and fronts probably aren't too far behind. If I order 4 from the Tire Rack, do I have an independent store install them?
  18. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    I thought Tesla claims 3% better range with the Primacy. It actually uses more Wh/mile so that would mean slightly less range?
  19. jerry33
    Texas
    I know Tesla said that, but I haven't found that to be the case. Problem is, I don't know all the parameters they used when they did their tests.
  20. nrcooled
    NoVA
    I have a shop near me that does all my tire installs. The SC is too far away to have them do it and my shop does a great job. There isn't anything special about the model s that makes the job difficult or special.
