Are These Additional Speakers?
Discussion in 'Model X' started by Brandon332, Jan 6, 2017.
Tags:
  1. Brandon332
    Brandon332 Member
    Hi All,
    I'm wondering, are the circled things on the images below additional speakers? I have the Premium and Fidelity Sound System Package, but no sound comes out of these. If they're not speakers, what else could they be? Has anyone heard sound come from these? Thanks!
  2. Tam
    Tam Well-Known Member
    Visalia, CA
    They don't look like speaker grills. There's a speaker grill for your tweeter at the bottom of the column where it meets the dashboard.
  3. Brandon332
    Brandon332 Member
    There are 17 speakers in the premium sound package. I can't figure out where all 17 would be otherwise. See the image below, what do you think? :0
  4. Winston
    Winston Member
    Western Australia
    I assumed they were the microphones.
  5. Tam
    Visalia, CA
    #5 Tam, Jan 6, 2017
    Here's a picture of Model S front speakers
    Those are located in the same position as the X but the S is missing a tweeter at front center dashboard
    You can count that the S has 3 mid-range speakers on the dashboard and same as the X.
    The S has 2 tweeters at the bottoms of A columns the same as the X.
    That's a total of 5 so far.
    The X has an additional tweeter in front center dashboard so 6 for X and 5 for S.
    You can continue to count with your own graphic diagram that you posted:
    Two Mid-woofers in front doors
    Two Mid-woofers in the wings.
    Two tweeters in the wings
    Two Mid-Ranges in hatchback door
    Two tweeters in hatchback door
    One subwoofer in right rear quarter.
    So that's another 11 in addition to 6 front = 17
    • Informative x 2
  6. Tam
    Visalia, CA
    That small rectangular thing is imprinted as "air bag".
    It might be a cover to access something that's called "air bag".
  7. Phil Seastrand
    United States
    Yes, those are the microphones for the Voice Activated system and phone integration.
  8. Drewflux
    Drewflux Member
    Australia
    They are the "A" pillar retaining bolt covers. Behind them is a 10mm bolt. The bottom of the pillar simply hooks into the dash.
  9. BigMskiman
    BigMskiman Member
    Pleasanton, CA
    Phil's right......you can tap on them while in a phone call to confirm
  10. Tam
    Visalia, CA
    Especially, when you have a long arm just to reach to the passenger A Pillar!
