It depends upon your needs. Are you running a server farm or a laptop.If you have a medical device that has its own backup you may not need one. Search for UPS on this forum. It has been discussed thoroughly. Some work better than others and some require adjustments to cohabit with Powerwalls.what is the best type of UPS to get?
Have you found this supplier works best with powerwalls?I think for sensitive electronics like servers, NAS, etc. it is a good idea to have one. They can crash in a few msecs. TVs, DVR, etc. seem to fine without them.
I have UPS units on my NAS, cable modem, routers, switches, etc. And for belt and suspenders, also on our desktop computers. All of our UPSes are from CyberPower.
I have done a search and the threads I read do not jump out. That is why having one that is just about UPS might make things easier to find. So which one(s) work best with powerwalls?It depends upon your needs. Are you running a server farm or a laptop.If you have a medical device that has its own backup you may not need one. Search for UPS on this forum. It has been discussed thoroughly. Some work better than others and some require adjustments to cohabit with Powerwalls.
I do not use one and can deal with the occasional blinking zeros on my Microwave.
that was one of the comments I remember hearing about is some units do not work with the frequency shift. So, if I boy some, want to make sure I get something that will workSorry, just a little off main topic...
I have several CyberPower UPS units around the house on the servers, NAS, internet cabinet, and important workstations. They are small 900 units just to protect against surge or the PowerWall switch over.
My 2x PWs run in self-powered mode. Every night my PWs serve my house loads completely with about 25-35% remaining at sunrise and recharge time. I feel ok with that level because we rarely have grid outages in Las Vegas.
At this time, the UPS units have not triggered yet. I’ve read a little about the frequency thing for like 62.5 or something, but I’m not sure if it’s something I should be concerned about yet.
Is the frequency thing something that happens when the PWs take over or just when the grid goes out and the PWs reach full capacity?
Just when grid power disappears. If the batteries take over while the grid is still up you won't see a disruption.Is the frequency thing something that happens when the PWs take over or just when the grid goes out and the PWs reach full capacity?
Thanks. I have read some have gotten the frequency changed to like 62? what is as low as you would want to go? Can only tesla make the change or can the installers do? ThanksSearch isnt working very well for me on the site right now. Search this section "eaton UPS". There are a few different threads with a lot of discussion around this topic.
The high level overview is
1. Because "sometimes" the swap from grid to powerwall power can be as long enough to notice (flickering lights, reset clocks etc) depending on where your power is coming from during a grid power outage event, many people put small battery backup units on "important" devices.
2. Whats "important" is up to you, and in general, you only need enough battery backup power to cover a few seconds while it swaps over.
3. Some battery backup devices do not handle the frequency being raised higher than 62 Hz, so when on backup power, when there is no grid AND the powerwalls are full, when the powerwalls raise the frequency to turn off the PV, it gets set to 65 Hz, which can cause these devices to not recognize the power flow (and beep, continuing to provide backup power until drained or the frequency is lowered.
4. UPS Devices from Eaton tolerate up to 70Hz so work fine with the raised frequency.
5. Most of us feel its better to get tesla to lower the frequency, since the higher frequency can cause issues with more than just UPS devices.
And to answer the engineer in you,
no, I can not definitively tell you exactly when you will notice the swap and when you wont. I have some suspicions but no proof
No i cant tell you what frequency tesla will lower your system to, when its installed. This is system dependent.
Yes, I can verify that I have an eaton UPS device (currently connected to my modem / router), and have tested it when the frequency was raised to 65hz. It worked fine.
No, I dont have a number for "most of us" here at TMC.
Dunno 'bout "best", but I use the Cyberpower 1500PFCLCD. The PFC designation means they have true sine wave output and work with newer computer PSUs that have Active Power Factor Correction. I have 4 of them for my computers and stereo, plus 6 older units that I cycled out of main service when I bought the new ones. The old ones cover non-critical loads.I have done a search and the threads I read do not jump out. That is why having one that is just about UPS might make things easier to find. So which one(s) work best with powerwalls?
And to further clarify, not always exactly when the grid disappears. If there is no AC coupled solar running, there us no need for frequency changes. When there is AC coupled solar producing, if the loads are large enough and the battery has to support the loads there should be no need for frequency shift. However because of the unpredictability, some people with critical prefer to use UPSs.Just when grid power disappears.
I wonder, though, if the power supplies in your equipment are rated to operate normally with those frequencies. The ATX12V Power Supply Design Guide for PC PSUs specifies a 47-63 Hz range, accommodating 50 and 60 Hz systems. Wouldn't it be better to have tighter tolerances in the UPS and have them trigger with the high freqs? You can set alarms to be silent, and you can shut down the equipment during the times the freqs are too high...3. Some battery backup devices do not handle the frequency being raised higher than 62 Hz, so when on backup power, when there is no grid AND the powerwalls are full, when the powerwalls raise the frequency to turn off the PV, it gets set to 65 Hz, which can cause these devices to not recognize the power flow (and beep, continuing to provide backup power until drained or the frequency is lowered.
Oh man, video encoding is such a slow process I can see why you don't want to do it twice.Have you found this supplier works best with powerwalls?
I want to protect my computers. I have one that I use for video encoding. Is the pits when it has been running for many hours and I lose power and have to start over again
Man, they have tons of models. Which one(s) model are you using? They have no issues with the frequency shifts?
