To Quartzite and back (for a burger!)
Having done Scottsdale to Quartzsite, or actually Scottsdale to Chiriaco Summit (236 miles on an 85 pack), all I gotta say is, set it at 60 and relax in the slow lane. Don't plan on going faster until you've made the trip a few times. Also BE AWARE that the heater on will suck your battery far more than air conditioning. No defogging, no fresh air fanning in if the inside temp is set warmer than outside temp.
We made it. Trip details and a few photos to prove we did it.
Outdoor temperatures ranged from 72 degrees when we left to 65 after sundown.
Used headlights (obviously) and no climate control -- perfect driving weather.
No significant winds.
No meaningful elevation change, although Quartzite is about 300" downhill from Phoenix -- takes more energy to get back.
Model S 60kWh, range charged Saturday to 197 miles rated range. I drove 65 mph in town and 80 mph once out of town. I arrived with 29 remaining rated range.
No other cars here charging -- apparently Carl's Jr. in Qaurtzite on a Saturday night isn't the local hot-spot.
Super charging is really cool -- and
fast, at least up to the 80% point. That really needs to be figured into anyone's time calculations -- super charging back to 100% does cost you quite a bit of additional time. I was getting impatient so I stopped once I hit 170 miles rated range, with 130 projected to get home. I cut very close. I slowed down coming back to Phoenix, 70 mph out of town and 60 mph in-town. (Roblab is exactly right --
just slow down and relax!) I pulled into my driveway with 13 miles rated range remaining.
The recharging was 156 miles per hour, 350 volts, 72 amps.
The Carls' Jr is..., um, well, it could use a little maintenance and remodeling. I'm also suspicious of any guacamole on a burger in a exit-ramp fast food restaurant in Quartzite. It is open 24 hours.
There is also a Burger King right across the street.
