At What Point Do I Contact Tesla?
Discussion in 'Model S: Battery & Charging' started by Piney999, Mar 10, 2017.
  1. Piney999
    Piney999 Member
    North of Spokane Washington, Earth
    So I have 2013 S85 and as of last September, my 90% was 225 and my 100% was 254... now, i just did a road trip, and my 90% is 209 and my 100% is 234... That seems like a rapid and alarming decrease in only 6 months. I just had my car in for an alignment 2 weeks, and was told they performed a normal safety check, and everything looked good.... Any thoughts would be appreciated. Thanks in advance!
  2. apacheguy
    apacheguy S Sig #255
    So Cal
    A couple other owners have observed this rapid decline and I believe a failed module was eventually diagnosed. If I recall, one of those owners was @ken830. You might try PMing him.
  3. Az_Rael
    Az_Rael Supporting Member
    Palmdale, CA
    I would contact them. You may have a bad module in your battery. My 2013 P85 has a 90% of 232 miles
  4. AmpedRealtor
    AmpedRealtor Well-Known Member
    Buckeye, AZ
    You likely have a failed battery module. Contact service for a diagnosis.
  5. Blup85
    Blup85 Member
    Chico
    yup, my p85 55k still shows 227-232 @ 90% (depending on if I have balanced them recently
  6. AmpedRealtor
    Buckeye, AZ
    you guys are lucky. My 2013 P85 w/ 56,000 miles only goes to 226 miles at 90%.
  7. Rifleman
    Rifleman Now owns 2 Model S's!!!
    Harrison Ohio
    My 2014 S60 is down to 159 @90%. My wife's 2013 S60 is holding strong at 182 @ 90%. I asked Tesla to run diagnostics on my pack, and they did, but they insist "everything is fine". I fear that getting them to replace a pack is going to be a challenge if the car is still capable of forward movement.
  8. seclinton
    seclinton Member
    Newark, CA
    2013 P85, just a shade over 80k miles.
    226 @90%
    245 @100%
    That's about 92% remaining capacity @ 80k miles, about 2%/10k miles. Not linear I'm sure. Actually up +2miles at 80k vs 224 when it was at 50k miles
  9. shady
    shady Member
    Morgan Hill, California
    I have exactly the same problem - it started occurring a couple of weeks ago. My 2013 S85 90% is 208 miles.
    I'll call Tesla and see what they say. I wonder if a Failed Battery Module is covered under the Battery Warranty?
  10. Piney999
    Piney999 Member
    when I contacted Tesla, they told me that software v8.1 calculates the miles differently, and that this is where my battery capacity has gone. I am not going to fuss much about it, but I will check my 90% & 100% again in July and see where I am at.
  11. SeminoleFSU
    SeminoleFSU Voluntaryist
    Atlanta, GA
    My 2013 has 63k miles and is 221 @90%. I've never seen anyone with a car the same year and similar mileage be lower than me so I think the OP should contact Tesla for sure
  12. SeminoleFSU
    Atlanta, GA
    Mines even lower. 221. Been 221-222 for a very long time 48k miles or so. I have 63k now I'll bet I'm even lower. Haven't done a 90 in a while
  13. asim120
    asim120 Member
    United States
    My 2014 S60 has 22k miles and gets 130mi @90% and 145mi @100% (rated). My Service Center said last week that the remote logs showed no hardware issues and that this was all due to a "firmware bug." I was charging to 75% daily and my daily SOC floated between 55-75%. They told me to charge to 90% from now on and to "follow up later."
    Good luck with your inquiries. I was pretty disappointed to be dismissed with "it's a firmware bug" along with no answer when I asked when the "bug" would be fixed.
  14. shady
    shady Member
    Just to update you on my situation (Similar to the OP) Tesla have had my car for a week now (running Diagnostics ). I've not heard back whether they've found anything - I'm enjoying the Insane mode Loaner too much :)
  15. Piney999
    Piney999 Member
    Shady, keep this thread posted on what you learn!!
  16. RayW
    RayW Member
    Cypress
    When does Tesla have to provide a replacement battery under the 8-year warranty? Does the battery have to be completely dead, is there some minimum capacity which is a tightly held corporate secret, or does it depend upon the generosity of the service center?
    Here's another rookie question: Does the predicted mileage take into account your particular driving "habits" and use of the HVAC? That is, does 209 miles @ 90% taking into account your most recent miles/kWh?
  17. Piney999
    Piney999 Member
    While I can't answer this question with certainty, that is what the service center alluded to. Software 8.1 takes into account your recent miles/kWh when it calculates your range, thus my drop after a winter road trip.
  18. shady
    shady Member
    Here is the latest on my situation.
    Tesla have had my car for just over 2 weeks now. They ran diagnostics and have determined that there is indeed a "problem" with the high voltage battery. The good news is that all repairs will be done under the battery warranty (my standard warranty expired a couple of years ago). The bad news is that - they are going to fix the battery, rather than giving me a new one!
    I don't have the details yet on what exactly the issue is, but this is how it will play out. They will swap out my battery for a loaner battery, and I can return the loaner car. They will then send my battery back to the factory for repair, at which point, they will swap it back.
    I'm actually looking forward to getting my car back - For the last two weeks, I've had a taste for what it's going to be like in 2019 when the white carpool stickers will no longer allow access to the HOV lane.
  19. JonathanD
    JonathanD Member
    OC, CA
    2014 S60 here, 25k miles on it, and max range down to 180. When I last took it in it was at 190 max and they said "it was fine" similar to other comments. They gave the rationale that the software update was making it display differently but that doesn't make sense -- the range still correlates exactly with 300 kwh/mi when I drive it. Now losing another 10 miles is concerning and am going to ask them again at next service. I usually charge 60-80%, only go to 100% once a month or so.
  20. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    Something must have gone bad-- for comparison I bought my 60 in 2013, it has about 33,000 miles, and rated range with 100% charge is 200 miles (4% loss from the original 208). I wouldn't wait for the next service to have it looked at.
