Note: This feature currently requires accessing the site using the built-in Safari browser.
Does this ever become a serious problem to the point of brake fade?Also it can even become limited with a warm battery at 50% charge if it's being used excessively, like if you're descending down a mountain for miles at a time.
ICE cars can use engine braking to limit brake use on long mountain passes, and the engine braking can continue without any ill effects. If regen goes away on a mountain pass, the friction brakes won’t last very long on our heavy cars.
Don't charge to 100% (or even 90%) at the top of the mountain, and you should be fine.Does this ever become a serious problem to the point of brake fade?
Weird, never had regen dots before, with limited regen, but had them today. Mid-50s. Battery at 75%. Drove about 25 miles, and the dots never disappeared, and I could feel that the regen was not fully there. I'm on the latest software 32.11.1
Never a serious problem in my experience, but I'm curious as to how they plan to manage regen braking limit on the Tesla Semi where it's critical.
The issue is that trucks have tremendous potential energy at the tops of hills, far exceeding the ability of friction brakes to manage a controlled descent on steep grades. Engine braking is much more critical for them than for cars due to the different ratio of mass to braking effectiveness.They will actively heat the battery. Semis don’t take as many short trips as cars do, so the impact to range and efficiency should be minimal.
T
Trucks will have to manage their battery usage very carefully in mountainous terrain. They need enough of a charge to get to the next destination, but also enough battery depletion to absorb the potential energy into the battery when descending.
I just realized there is one other option if there is too much potential energy for the batteries to absorb. They could dump that energy into a large set of resistors to simply generate heat that is vented away.
I’m not sure why that’s an issue. The battery pack can be top-locked so there is always storage space available for regen. Actively heat the battery before the start of the day’s work and you’re good to go. The heating can even be done from shore power so that no range is lost.
One question that could be asked is whether regenerative braking will be sufficient to brake an 80,000 pound, fully loaded semi truck. Well, let’s look at something else that uses electric traction motors to provide braking: 8 million pound diesel-electric freight trains. They use something called dynamic braking instead of regenerative braking. All that really means is that the electricity generated from braking has nowhere to go on a diesel-electric freight train, as the electricity for the motors is supplied by a massive diesel generator instead of a battery. As a result, they route the electricity into heating coils on the roof of the locomotives.
It can be an issue because the energy can exceed the ability of the battery to absorb it.
But looking at this a bit further, I found a page that describes this exact scenario, including the resistive heat: Tesla Semi Trucks Won't Use Runaway Truck Lanes As Often As Others | CleanTechnica
