Atari controls - full screen mode
hulk2k17
403
171
DFW Area
What are exact controls used when playing in full screen?
Lunar Lander is the only one I've figured out: Right scroll wheel up/down to control the rotation of the craft, Press in the right scroll wheel to use the thrusters.
kirkbauer
623
241
Atlanta, GA
I just found out today that you can also turn the steering wheel to control the Lunar Lander.
For Centipede you use the steering wheel as well.
For Missile Command you actually touch the touch screen to move the aiming point and click the scroll wheels to shoot.
hulk2k17
403
171
DFW Area
Won't this turn your wheels and isn't that generally bad on your tires while stationary?
For middle command you touch the missle bases to shoot the missle from a specific base.
I'll try that. Thanks both for the help. Any suggestions for Asteroids?
SpudLime
1,420
2,452
Leesburg, Va
Man. I finally got the controls down.
For missle command, on full screen, I drag the plus sign around with my finger. And then tap the closest missle launcher.
For centipede, in full screen, I drag the shooting bug around with my finger and hold in the scroll wheel for constant firing.
For lunar lander, on full screen, I use the steering wheel to rotate the lander and push the scroll wheel to modulate the thruster.
