contaygious
I have premium, dolby off, flat eq except boosted bass. It is better but still no rear sound obviously. The spectrum seems improved though. Make sure your dolby is off! What a dumb feature.
Do you fade to the back? They heavily stage audio to the front speakers, and the subwoofer input, at least to my ears, seems to be tapped off of or otherwise associated with the levels at the rear speakers. Fading to the rear substantially improves immersion and bass response, IMO.While improvements may have been made in the EQ and signal processing they are to the detriment of the bass frequencies. Even my wife commented the other day that the subwoofer in the back rarely fires.
Putting music tastes aside, Ludacris' track "Area Codes" used to have the best sounding bass in our Model S. Now it is laughable. Tesla should not have changed any of the bass signal processing without at least ensuring that the changes did not make things worse!
It might, but you can't change those, so...I can test the fade to back settings later but I think this whole thing has to do with the various settings that govern subwoofers; LFE, crossover point, levels.
Here is my opinion. I spent an hour in a car without the Premium sound system and and hour with one that had it. I played the same songs. I set both system to my liking and found both acceptable. You do have to add more bass and treble and leave the mid range a little flat to the base system to get a good sound. It was easier to find a good balance with the premium system and it did sound better (mainly more bass). However, it did not sound $2,500 better than the base system to me.
You probably need to determine the ages of the two cars, as well. Many have noted that there have been significant improvements to the upgraded system since the early cars. I did a similar, though shorter, test as you with FLAC on a USB drive on showroom cars and came to a different conclusion: the difference was night and day after some tweaking. They were both brand new September builds, and had the most recent components.
Being worth the $2.5k is highly subjective, though. I suspect the answer is 'no' for most people, even if they felt the difference was obvious.
I decided I wanted better sound but didn't want the hassle of mucking about with it, and the lack of a subwoofer was particularly disappointing. I haven't regretted the upgrade, but it certainly has room for improvement.
Mine is the same. The more I fade to the back, the less bass. If I fully fade to the back, it literally sounds like it's a transistor radio my grandpa owns to listen to cricked on long wave. No exaggeration. So I'm not sure that's not 'normal'. We often fade to the back when the kids want to listen to their crappy music (One Direction, Kesha etc) but even they complain it sounds horrible.Any fade to back more than 2 or 3 kills my sound, and totally kills the bass. Dolby on my lossless AIFF off the USB stick also sucks. The premium sound in my car is only in the front. Looks like its time for a visit to the service center.
As mentioned, I had the same issues with our first S and unfortunately service looked at me cross eyed when I tried to explain it... it seems that they are largely in the dark with respect to how each of our sound system setting are tweaked. I'm no longer convinced it's a matter of newer vs older builds, I've heard good and bad on both older and newer cars. I suspect there is something commonly malfunctioning.
Are we sure it's just not the source? Blown fuses, etc. aside, the source makes a dramatic difference.
Wow...that would have possibly resulted in the best sounding car in the World. I once owned a Hyundai Genesis....and the sound system was fabulous. They bragged about how it was the same stereo system that is used in the Rolls Royce Phantom vehicles. The overall layout of speakers, the total number of speakers and the quality of sound was amazing. One day, Tesla may take the sound quality in the Model S seriously. It seems that it really wouldn't take much to make it an outstanding system.
Anything Hyundai cannot have anything comparable to a Rolls Royce!
Unbelievable to think that!
Even mentioning Hyundai and KIA crap on this page should be banned!
Hmm. Pretty unusual. Have you tried isolating individual speakers (to the extent possible with only balance/fade) to see what that does? Kind of sounds like you have an issue with your system. I can pin the sound to any of the four corners of the car and still have it sound pretty good, and if anything, fading to the front kills the bass.Mine is the same. The more I fade to the back, the less bass. If I fully fade to the back, it literally sounds like it's a transistor radio my grandpa owns to listen to cricked on long wave. No exaggeration. So I'm not sure that's not 'normal'. We often fade to the back when the kids want to listen to their crappy music (One Direction, Kesha etc) but even they complain it sounds horrible.
100th may be right. Perhaps there's a widespread failure case.
I'd take your USB drive to test on the other cars in the showroom, provided your service location has one. That's probably the easiest way to demonstrate a problem. Otherwise you'll probably get the "It sounds good to me" routine.i'm heading to the service center this afternoon. I'll update with any news.
