Audio Volume lower after last update?
sgmorton
73
51
Baytown,Tx
I have the UHFS and I noticed that I was having to turn the volume up to 6 or 7 to hear the music over the tire noise. Normally I would keep it at a 4 or 5. I went to the EQ settings and now it maxes out at 8.0 am I remembering that it used to be a 10.0 at max on the Eq? just curious if I am the only one I need service or not?
Sam
boaterva
7,562
3,736
Northern Virginia, USA
One answer I've heard is that because the max range is now 8 dB plus/minus, you can use the max if you need to, and then you can push your volume up a bit to compensate (raise your baseline). I've not seen anybody say why the the change from 12 to 8.
sgmorton
73
51
Baytown,Tx
Well I for one hate it. It took all of the oomph from my sound and flattened the curve.
Reactions: selfbp
trayloader
315
369
GERMANY
Instead of fiddling around with this they should, after 6(!) years finally offer us a loudness option furthermore based on the speed. Every 15k car offers this standard.
The old, 7.1 fader worked in realtime so You heard what You set. Now since 8 you have to lift Your finger.
What dumb***f**s work at the software and U.I. department?
What a letdown.
Reactions: Ande
Kano
24
10
Bay Area
Please, everyone, report this as an issue. Maybe they'll bring the older equalizer back if enough owners make a stink. Our UHFS sounds awful now.
Where's the best place to report this?
My model x is suffering the same issue... Sounds awful now :(
