Auto high beams
Discussion in 'Model 3' started by robl45, Feb 13, 2021.
  1. robl45
    robl45 Member
    I have auto high beams checked but the auto high beams image doesn't show up on left side unless I push forward on the turn signal stalk. Is that normal?
  2. Tarpan
    Tarpan Member
    Vancouver, BC
    I have never seen auto high beams turn on. Been surprised a few times.
  3. P3dStealth
    P3dStealth Member
    Once you have it checked you also have to pull the lever once. Then they will turn on and off auto.
    It doesn't work good in my experience. Might work better for people in rural areas with darker surroundings I suppose.
  4. danarcha
    danarcha Member
    South Bend, IN
    That seems normal. I usually have to push the left stalk forward once to get the grayed-out auto high beam icon to appear. Then auto high beams will work. Well.. it doesn't work great.. it functions about as well as auto wipers. But it is active after I push the stalk forward once.
  5. robl45
    robl45 Member
    Every other car I had they stay auto once you set them.
  6. Big Earl
    Big Earl bnkwupt
    Springfield, VA
    It will stay in auto once you set it.
    There is the auto high beam icon in the setting menu that toggles between automatic and manual high beams.
    Then you have the forward position on the turn signal stalk. That enables and disables high beams. When auto high beams are selected, pushing the stalk forward enables them and the gray auto high beam icon will appear. Push forward again and it disables them (low beam only) and the gray icon will disappear.
  7. robl45
    robl45 Member
    No I mean every other car stays once set permanently. I don't have to set auto high beams every time I start the car
  8. leonar40
    leonar40 Member
    Bloomington, IN
    Part of my drive everyday is on a two-land country road. Works amazing for that.
  9. Big Earl
    Big Earl bnkwupt
    Springfield, VA
    The Tesla should stay wherever you had it last. Check again. Is yours behaving differently?
  10. skygraff
    skygraff Member
    Chicago
    Some confusion with terms here.
    Tesla decided to implement a hybrid design where you enable auto high beams in the settings then, you use the stalk to “prime” them. That way, if the auto system is over or under reacting, you have a quick and easy way to disable it while driving rather than having to navigate the screen.
    So, in short, it works like other systems but there’s a safety valve.
    If you don’t trust automation at all, don’t enable it in the settings but, if you like automation, enable it then prime it. If it starts blinding people or you just don’t need it for a little while when it keeps coming on, a simple lever flick will suspend it until you want to give it back control.
    Not to dive into another subject but might be nice if the wipers were as carefully implemented.
  11. Tiger
    Tiger Active Member
    Estonia
    I see this a bit differently - I myself have poor vision in dark and use the stalk to actuate high beams manually when it does not yet pass the threshold of switching on automatically. Whenever there is oncoming traffic, I switch back to automatic (from stalk).
  12. robl45
    robl45 Member
    Correct, I have to push the stalk everytime I drive.
  13. jbiggs2
    jbiggs2 Member
    OK
    I have it set to auto but still have to enable it once my headlights come on. It is NOT automatically set even when you've selected that in the lights menu. Design flaw.
  14. CameraJim
    CameraJim Member
    West Chester, PA
    The auto headlights have been working on my M3. In fact, they work better than I do, as I rarely remember to turn on my high beams on dark roads. I live in a small town, and the auto headlights stay on low when I'm on lighted streets and turn up as I leave town. So far, I haven't had any other drivers flashing back to me in complaint about high beams,, as they seem to dim quickly. It works at least as well as the feature did on my Lexus, though I must admit I miss the auto turning headlights on that car.
  15. skygraff
    skygraff Member
    Chicago
    Not different behavior just different usage pattern. Just another reason it’s a valid design choice. That said, if it gets good enough that you can trust it or they let you dial in your vision needs, you might be able to just keep it on automatic so you don’t have to wait for the moment your poor eyesight picks up the vehicle before you let the auto beams stop blinding that driver.
    Hmm, I haven’t tested it lately (except by accident) but it used to stay in auto from drive to drive. Will experiment but, unless they made a specific change and noted it in the manual, I’m guessing it’s not a design flaw but, rather, another update induced bug. If it has been changed and noted, can only guess they reverted to that behavior because their confidence in the auto system wasn’t as high as they’d like; can’t say I disagree as an urban dweller with good night vision. Another reason it could benefit from having user/location based settings rather than just an on off switch.
  16. Peteski
    Peteski Active Member
    UK, Milton Keynes
    In every other car I've driven with auto-dipping high beam you still have to manually switch on the high beam, although that typically means it stays on if you leave the stalk in the physical high beam position. The auto part is the dipping, not switching on the high beam.
    The difference with the Tesla M3 is that the high beam switch is not like a traditional stalk that stays in a physical "on" or "off" position - it is just a momentary micro-switch. Although I'm pretty sure mine (2021 car) remembers what setting it was last left in. So if you leave the car with high beam switched on (auto-dipping or not), it remains on next time you get in the car. All cars have the ability to manually switch from main (auto-dipping or not) to dipped beam only and I would imagine that is very much a legal requirement.
  17. Peteski
    UK, Milton Keynes
    It's not a design flaw. Auto-dipping main beam doesn't mean the main beam has to be switched on all the time. You can still switch from dipped to (auto-dipping) main beam. I'm pretty sure that's a legal requirement in all cars. As I mentioned above I think my M3 remembers whether or not main beam was switched on when you last left the car.
  18. robl45
    robl45 Member
    It is because we have to switch it every time back into auto high mode. My mercedes stayed in that mode, my wife's infiniti stays in the mode.
  19. surfrasch
    surfrasch Member
    Hollis, NH
    They most definitely made a change on my last update in December. Mine used to remember the setting and I didn’t have to engage it with the stalk to start auto. Now I have to start it up each time. Not saying whether it’s good or bad, but definite change.
