mspohr
I'm not sure moving the notification to the dashboard would make much difference. Just as easy to ignore it there. Maybe an audible warning?The auto open/close works great in most cases, and once I got used to it, I stopped looking at the console screen when pulling in and out of the garage.
And, that's a problem...
The auto open/close works great - when you have only one car using the garage door and you are leaving/arriving at the garage. But, if you have any variants, that automatic open/close creates unexpected results - and because you quickly get trained not to check the touchscreen when driving to/from the garage door, you forget that the door will be sent a command to open/close.
For example, if the garage door is already open when you approach it, the command will be sent to "open" the door - and since the door is already open, the door will start closing as you are entering the garage. As long as the door opener has a working and properly configured sensor at the bottom of the door, the door closing sequence should be aborted. But if there's a problem with that sensor - or there isn't a sensor, there is a risk the door will hit the car, as the car is entering the garage.
Like the auto-air suspension system - the auto open/close should provide an indication on the dashboard when something is being done affecting the driving conditions. Since you quickly learn to stop looking at the touchscreen when approaching/leaving the garage (and rely on the auto open/close), having something displayed on the dashboard would increase the likelihood of noticing that the car was doing something automatically for you - and warn you if it was something you didn't intend.
Also,the MyQ system knows if the door is open or closed and the car could make an informed decision to move the door (or not).
