Auto Homelink issues?
Discussion in 'Model S: User Interface' started by tliving, Jan 9, 2016.
  1. AWDtsla
    AWDtsla Active Member
    NE
    I never get that. Can you take a screenshot of your "Notifications" panel in the Tesla app?
  2. maddog1762
    maddog1762 Member
    Rock Hill, SC
    Notifications
    - - - Updated - - -
    This notification comes up every time home link opens or closes the door. When I summon the car in the morning the door opens I get a notification and when it closes it I get a second one. Painful. Thanks
    - - - Updated - - -
    Of course I do have home link on auto open and close
  3. msnow
    msnow Active Member
    SoCal
    Guys, please see post 65 above. It's just a confirmation that a setting on the 17" Homelink tab changed. It only happens when you enable it or disable then enable again. It NOT a recurring alert.
  4. msnow
    msnow Active Member
    SoCal
    I got auto close auto close to work 3 times in a row. FWIW here's what I did.
    1. Get in car
    2. Open garage door with homelink
    3. Step on brake to turn on car, shift in reverse
    4. Homelink text pops up with text re auto close at 10 ft
    5. Back out and garage closes.
  5. tstafford
    tstafford Supporting Member
    Nashville, TN
    I was struggling with it too. For me, both Close and Open work however it is critical that I use the wall button of my garage to start the journey. If I use the Homelink Button to open my garage door (from inside) then Auto Close is disabled. I'm kind of disappointed by that only because I like opening the door from inside the car. But whatever. Overall a very, very nice feature.
  6. jimtelsa
    jimtelsa Member
    Simi Valley
    When I came home today and drove up and saw the garage open I was like wow it works...
    My Tesla is an out door car so when leaving I open the car from in the garage wall mount opener, and started driving it went down.
    First time all works great. Another cool feature that just came to me without asking. Thanks Tesla.
  7. bob_p
    bob_p Active Member
    It appears the recorded GPS location for Homelink is critical in getting auto-open/close to work reasonably well.
    For me, it took several attempts at resetting the location, until I found a location that works reliably - and I may make another pass at setting the location, because it's too close to my garage - since the auto-close in 20 feet message comes on immediately when I start the car inside the garage - and the auto-open doesn't trigger until I'm almost at my garage door.
    At least for me, resetting the location didn't work well when pulling out of my garage that reading wasn't as reliable as the GPS location I get after driving the car and then pulling into the driveway. Resetting the location when returning home seems to be more accurate - probably because it's got a stronger GPS lock after driving - than the car has when pulling out of a building. [Don't know if the car is getting a GPS location from our WiFi network - which will never be accurate for Homelink geolocation.]
  8. Cyclone
    Cyclone Cyclonic Member ((.oO))
    Charlotte, NC
    It's the same for me. But if you try it from inside the car, are you using Homelink to open the garage door before or after you hit the brake to "start" the car?
  9. FlasherZ
    I don't have that problem. If I get into the car, use the car to open the garage door, then drive out, it will still auto-close. I can say that auto-close has been entirely reliable for me.
    My issue is that the auto-open is flaky for me based upon the driving speed up my driveway. Driving up my lane road, the car gets turned 180 degrees to pull into my garage stall. If I drive at > 10 mph, the car gets to a spot where the opener receives the signal by the time auto-open engages; if I drive at < 10 mph, it will try to open when I'm aligned with the brick wall that will block the signal. I've tried various different locations, to no avail.
    My recommendation to Tesla was to allow for us to set different, precise locations for auto-open vs. auto-close. I'd want auto-open to occur when I'm on the back side of the garage, where the signal can travel through the windows, but I want auto-close to occur immediately after I back out.
  10. Soolim
    Soolim Member
    Vancouver, BC, Canada
    I think you just discovered an undocumented feature on Tesla working with Home Link on manual open - auto-close. Once power is applied to the car, it will only do one auto operation (open or close). To manual open with auto close, manual open needs to be executed before stepping on the brake to start the car.
    One scenario for unsuccessful auto-close is:
    If I auto-open to get into the garage to let my passenger get off without shutting down the car, then leave the garage, the garage will not auto-close.
    Maybe Tesla should just auto-open when I want to exit, and auto-close after exiting, something similar to summon. I don't have summon (yet), being in Canada.
  11. AWDtsla
    NE
    Getting used to this feature. So after reseting location INSIDE the garage, auto-close seems to work reasonably well, 20 foot countdown which means the car has cleared the garage door by about 3 feet. But auto-open seems to open really early, opens at the end of my driveway, which is probably another 60 feet away.
  12. brucet999
    brucet999 Active Member
    Huntington Beach, CA
    Would that not work the same if you opened the garage door with the wall button before you got into the car?
  13. Soolim
    Soolim Member
    Yes. It should.
  14. msnow
    msnow Active Member
    SoCal
    Probably and I will test.
  15. smilepak
    smilepak Active Member
    Eastvale, CA
    I actually agree with this. Auto pilot and summon feature to me are merely sales / marketing driving. Auto pilot technology is too new to trust full time. Not to be confused with the features surrounding auto feature. The feature surrounding auto pilot like adaptive cruise control, lane warning, collision warning, etc., are useful tool. To truly expect self driving and auto pilot itself, so one can put on make up, chat on the phone, or do whatever they do other than two hands on the wheel and focus on the road is absolutely silly.
    I do like the garage open and close. Neat little functionality to add w/o costing owners more money and add value.
    What I was depress is not seeing more apps. I would think at this point, Tesla would open up their API for other apps like Spotify, Pandora, etc to be added to the console. I read another thread about why would Tesla pay for those service. They shouldn't. I don't mind subscribing to them. Heck I subscriibe to XM for years now. I was happy to cancel it knowing the Tesla would give me nice Internet apps option.
  16. smilepak
    Eastvale, CA
    Seem to be working fine for me. What I did was first back my car out of the garage and leave the garage door open. Back the car out approx 10-15 feets from the garage door because I wanted the open feature to start opening a bit earlier than directly in front of the garage.
    Put the car in park, while the garage is still open. Activate the auto open and auto closed. Then click on "RESET LOCATION". I than manually closely the garage via the autolink button on the console and drive off.
    When I got home, approx 25 feet from the house, auto homelink pops up showing me distance before garage will trigger open, as I approaches it, the garage door open and I drive in. When I back out the garage and reaches that GPS point where I reset originally, it closes the garage door.
    What it doesn't do, i dont think is while the car is physically inside the garage it will open and close your garage door. Only as you approach the GPS point and reverse to the GPS point.
  17. map724
    map724 Member
    Phoenix, AZ
    Exactly. I'm happy to pay for Spotify - just give me the app with Tesla complete integration!
  18. AWDtsla
    NE
    It doesn't but it should. Why else put the car in drive/reverse? It's as if the function was specified by a committee and then handed off to an intern. Which is sort of my opinion on anything that's gotten added to the UI.
  19. brucet999
    It makes sense that auto Close would not know when the car is far enough into the garage to close safely.
    It appears from what people say here that it is technically not "auto close" or "auto open" but rather "Auto Activate HomeLink". I would guess that if someone opened the garage door while you were away, the system would auto close the door upon your return.
  20. Andyw2100
    Andyw2100 Supporting Member
    Ithaca, NY
    Actually Cyclone had pointed this out days ago, way back here:
