Auto-close is not reliable, it has worked three times for me since last update. Auto-open always works. I have tried reset numerous times and it still doesn't auto-close like it's suppose to.
Once I got it right it has worked every time for me.
Ditto. Working flawlessly now after resetting the homelink setting (with front of car only a couple of feet from the garage door).Auto open and close work fine for me... multiple days now. Yes, I open the garage door with the wall push button before getting in the car (no change in habits or process from before), back out and it closes, come home it opens. I did reset the auto close location on the first day (a few feet outside the garage) and that is flawless now.
I still think the Auto Homelink process's GPS routine is "assisted" by seeing the home wifi connected. Similar to "phantom chargers", every time they I've noticed them, the car wasn't connected to the wifi.
The Release Notes are somewhat vague, saying that Auto-Close will close the door "when you leave your home." The Owner's Manual is more precise, saying that it closes the door automatically as you "drive away".I've obviously misread the release notes for 71 re Homeline: Auto-Open/Close. I did not understand that when you put the car in reverse the car should auto open the garage door when backing out. One can infer from the notes that this is the way that it should function. My garage door will not open when backing out unless I open the door from the manual switch on the wall. Then when I put it in reverse, the drop-down menu appears (Auto-close in 20 ft SKIP). Then I back onto the driveway and the door will close. Everything else seems to work as designed and the summon does auto open/close the door in all cases. But, as said above, it will not open the garage door when manually backing out. As others have alluded in previous posts, it appears that this Auto-Open/Close, although it works properly for some, is half baked for a lot of us.
Edit: Meant to say 7.1 vice 71.
Departure is hit and miss. I can't work out what sequence of events might be causing it to fail (or work for that matter). Simple logic would suggest that if the car leaves the garage, the door is in the up position... Duh! Therefore, why would it matter whether you lift the door with the wall switch or from the car? And clearly, if the car knows it entered the garage when last driven, it must therefore assume when it moves next (in the opposite direction), it's leaving the garage. It just doesn't seem like the logic should be that hard to code.
You can bang your head against the wall, say "This is how it should work", and keep struggling with it. Or you can incorporate what Cyclone figured out, which is the way it is actually programmed for now, and where it in fact does matter whether you open the garage door from inside the car or not.
Do I think this needs tweaking by Tesla? Of course. But when you write above "Why would it matter..." it makes it sound like you think it shouldn't matter, and are unaware of the fact that it has been pretty conclusively determined that for now, due to the way Tesla programmed this, it just does.
Interesting. I did read this upthread after doing my own experiments. FWIW I tried using the Homelink control perhaps twice to open the door while parked inside. That was just to see if it NEEDED that process to trigger the auto close function. My less-than-scientific conclusion: No. Every other time, the door has been opened via the wall switch as per my habit. And that procedure has been hit and miss. So I'm not sure if I can say Cyclone's answer is the whole story... although it certainly seems reasonable.You can bang your head against the wall, say "This is how it should work", and keep struggling with it. Or you can incorporate what Cyclone figured out, which is the way it is actually programmed for now, and where it in fact does matter whether you open the garage door from inside the car or not.
In a nutshell, what Cyclone figured out is that the car will only send a signal automatically once per time the car has been powered on.
So if you get in your car in your garage, turn it on, and open your garage door to leave, the car is not going to close the garage door for you. On the other hand, assuming it is set up properly and otherwise working, if you either open the garage door using the wall opener, or get in the car and open the garage door using the Homelink button, but do it before you have actually powered the car on, when you pull out of your garage the car very well may close the garage door for you. You will know as soon as you power the car on if it will or it won't, as if it will, you will have the Homelink screen up, with the countdown / skip option showing. If that isn't up, the car isn't going to close the garage door for you when you leave.
Users shouldn't have to care. Shouldn't take a software engineer to figure out how the car does/doesn't work then tell Tesla how to do it right.
Absolutely. The possible situations faced by users are limited. The logic shouldn't be that tough to nail down.Users shouldn't have to care. Shouldn't take a software engineer to figure out how the car does/doesn't work then tell Tesla how to do it right.
Lost me on that, particularly the part about it seeing the home wifi connectivity.
If you or someone you know has an iPhone, you can test this. Turn off wifi and then open an app that uses GPS. The phone will complain that GPS accuracy is better with wifi. I.e., the phone can use the wifi networks it sees in range to help assist the calibration of the GPS and determine its location better.
I suspect similar things happen in our cars and when the car can see your home wifi network, it more accurately thinks it is at home vs. a neighbors house and this may help Homelink.
As an experiment, I deleted my home wifi from the car for a week. Homelink stopped working every time and one time I got a "visited charger" a couple doors down from my house. Since connecting to my home wifi again, Auto Homelink has been flawless for me. Perhaps this is a coincidence, but it didn't hurt anything either, so my car is programmed to connect.
I guess Tesla program it this way:
1. Your car does not know what is the state of your garage door (open or close)
2. Upon arriving at the geolocation of your home (mine is detected 20 ft from the garage door), your car issues a command to activate the garage door. If it is open, it will close. Most likely it is closed so it will open.
3. When the car is power cycled from off to on at your geolocation, it knows the car is at home. The Home Link countdown starts when you put the car on drive or reverse. Ones you move your car by 15 ft, your car issues another command to activate the garage door. If it is previously open, it will close.
If auto-open on arrival works but auto-close for departure does not work. Reset your geolocation while the car is parked inside your garage. YMMV.
Try using the wall button to close the garage door after arrival, and to open the garage door prior to departure. I think this simplifies matter. This has been working for me since day 1.
I would just add 4. The command will only activate once per power cycle. So if you pull up to your house and the garage door opens, you must exit the vehicle and get back in before it will auto-close. So if you had a passenger go inside to grab something, you won't get auto-close.
