Auto Open Passenger Doors with c528869
Discussion in 'Model X' started by VicG, Jul 21, 2017.
Tags:
  1. VicG
    VicG Member
    Californai
    I hope I didn't make a mistake - but I just got the new 2017.28 c528869 update last night. I noticed that if I double tap my keyfob - the front driver door opens. Another double tap opens the passenger door!
    This was the one pet peeve I had with my X - I couldn't open the passenger door, only the falcon doors from the keyfob. That apparently has been solved.
    Another alternative is that this feature was always there, and I just discovered it today, which if true, then I apologize for attributing it to this new release!
    Vic
  2. alcibiades
    alcibiades Member
    IL
    Totally agree it is a nice feature! I use it mostly so my teen doesn't have to put her precious phone away to get in the X with me.
    But it's been out for awhile. :)
    • Funny x 2
  3. VicG
    VicG Member
    Californai
    The Easter egg menu pull down is now working in this release. Hope that's at least new :)
  4. Jmedlin
    Jmedlin Member
    San Francisco Bay Area
    It's always been a feature for me. So I'm not sure it's new.
  5. NerdDoc
    NerdDoc Member
    New Jersey
    #5 NerdDoc, Jul 21, 2017
    Have the update, but doesn't work on my non premium package X.
    • Disagree x 1
  6. outie
    outie Active Member
    SoCal
    It's been there for a few months... glad you discovered it ;)
    Now, if it works WITHOUT enabling auto-present, then it's new.
  7. hly
    hly Member
    NJ
    it was new to me when the delivery specialist showed it to me in March :)
  8. rainforest
    rainforest Member
    Vancouver
    Doesn't work on my car
  9. outie
    outie Active Member
    SoCal
    Only for PUP cars. If you have it you also need to enable "Automatic Front Doors", which turns on auto-present, double click for driver door, and subsequent double click for passenger door.
  10. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    Hm, I think this appeared at some point, since I recall a post where there were complaints about not being able to open the passenger door from the Fob (as OP mentions). Of course, this sort of thing isn't well documented.... Anyone know when it did appear? It can't have been there all along! :D
  11. hly
    hly Member
    NJ
    has been here since March for sure
  12. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Powered front doors are part of the PUP option. Your front doors are not powered.
    Note that the PUP description at Order a Model X refers to a "self presenting front door". It should say "doors".
    • Disagree x 2
  13. Yggdrasill
    Yggdrasill Active Member
    Kongsberg, Norway
    #13 Yggdrasill, Jul 22, 2017
    That's not correct. They are powered.
    Pressing the door handles make the front doors fully open, you can open/close all doors from the touchscreen, and close all doors with a triple click on the fob. If you get in and press the brake, the drivers door closes. I haven't heard about this two click feature. I will have to check to see if it works, but I think I would have discovered it by now.
    Edit: Double click doesn't do anything for me. Non-PUP with 2017.28 c528869.
  14. Kurt'sX
    Kurt'sX Member
    San Diego
    I want to try this also.....its been aggravating to be able to open all doors except the front passenger side. I have the PUP and have wondered why I can open and close the door with the screen, can close it with the fob, but couldnt open it unless I pushed the door handle.
    This is obviously a "First World" problem :), but I sure noticed it when I was given a non-Tesla ICE loaner and kept pressing the brake expecting my drivers door to close. Im so used to telling my passengers "Dont touch the doors....they are automatic!"
  15. boaterva
    Hm... it's also not in the 'hard copy' PDF manual. It refers to the second double-click as unlocking everything. Somewhere this was extended in PUP's to opening the passenger door, an excellent addition/option. Is this configurable in Settings as to whether it will do 'global unlock' or 'passenger'? The auto-present part is, of course.
  16. Xminus6
    Xminus6 Member
    Bay Area, CA
    That has always worked for me since December pick up.
    Just an issue of semantics but it’s not really automatic, it’s remote. I thought this was about the passenger door auto-presenting like the driver’s door if you approach from that side.
  17. Insight75
    Insight75 Member
    Mount Olive, New Jersey
    Got excited when I read this.....but.......still have to enable auto-present for this to work. I have this disabled because the door opening every time I walk by the car is quite annoying. Still the fact that even with this disabled, the car turns on when I walk by. Really wish I I could shut all the auto stuff off and still use the fob to open each door. Easy software fix....hoping to see this in a future update.
  18. rainforest
    rainforest Member
    Vancouver
    Doesn't turning off auto present defeat the purpose of buying PUP?
  19. outie
    outie Active Member
    SoCal
    Yes, no, maybe. There are still other stuff in PUP... I have requested that they decouple automatic front doors with auto present, but nothing has been done for months (ever since auto passenger door came out).
    I've also requested that they make a geofence option for "keep car unlocked at this location", yet nothing has been done. I don't think both requests are out of the line but it would make a much better experience.
  20. Insight75
    Insight75 Member
    Agree. Sounds like I'm on the same page as Outie. This would help me get the most out of the option.
