Auto-Presenting Doors not working
Discussion in 'Model X: User Interface' started by Dr.Will, Oct 3, 2017.
  1. Dr.Will
    Dr.Will Member
    Irvine
    Hey All,
    just had this issue come up starting this morning. My self-presenting door worked well yesterday but stopped working as of this morning. When I walk up to the car it doesn't open, when I press the door handle the car door doesn't pop open. The door will only open when I unlock the car first with the fob then press the door handle. I made sure the "passive entry" was on, did the reset, toggled between on and off for the "passive entry" and still nothing.
    Anyone else experiencing this issue or have experienced it? Taking it into the SC next week but just curious to see other's responses.
  2. jay-bay
    jay-bay Member
    Idaho
    I'm experiencing the same thing. Were you able to get the service center to fix this?
  3. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    For anyone with this, have you tried toggling Automatic Doors? I’ve seen some weird things come and go, like the car wakes up with the fob nearby or it doesn’t. I assume it should, even with Auto on and Passive off. (It wakes up (lights flash), but I still need to open the doors/unlock with the fob.
    But at one point the lights weren’t flashing in this case. Toggling Auto to off and then back to on fixed this, if this is the correct state of affairs.
    So, also try toggling Automatic Doors. And I assume leave Passive enabled, since you want the doors to present.
  4. Dr.Will
    Dr.Will Member
    Irvine
    My service appointment is next week so I’ll let you guys know once they tell me what happened. If anyone else experienced this please do share.
    I’ve tried toggling the on and off for the Auto doors and still nothing.
  5. bbcoach51
    bbcoach51 Member
    SoCal
    I've had the same thing happen with my 100D MX. Tried toggling on/off etc. Still not working. Will be interested in what you find out.
  6. TexLaw
    TexLaw Member
    Bellaire, TX
    This may not be your issue, but my Ms typically does detect the fob if it's in the same pocket as my cell phone. There's no problem if I actively unlock the car, though.
  7. Solargrapes
    Solargrapes Member
    I posted regarding this same issue awhile back. SC replaced a BCM and we haven't had an issue since.
  8. Dr.Will
    Dr.Will Member
    Irvine
    BCM, does that stand for body control module? I'm just taking a stab in the dark.. how long did that take?
    thanks!
  9. Solargrapes
    Solargrapes Member
    Yes, body control module. Only took a couple hours once part was in stock.
  10. Dr.Will
    Dr.Will Member
    Irvine
    Thanks Solargrapes... I wonder if this is something a ranger could do?
  11. Solargrapes
    Solargrapes Member
    I tried getting them to send ranger but they wanted the car to order / install correct module.
  12. Dr.Will
    Dr.Will Member
    Irvine
    Just completed the repair, it was the body control module that needed replacing. they had the park in stock and completed it in a few hours. Be sure to bring in both keys to get reprogrammed; I had to run back home to get the second key fob.
  13. invisik
    invisik Supporting Member
    Minneapolis
    I believe I had this same unit replaced too, but also I find sometimes the door won't swing open by itself. The SC recommended opening and closing it 2-3 times in a row, to help re-adjust the sensors. After doing that, it works fine again.... (for a while)....
    -m
  14. AdamHLG
    AdamHLG Member
    Baltimore, Maryland
    Well, looks like this is a trend at least for this thread. My auto presenting driver door failed in my 2 week old 100D. It's at SC now. I'm told it's the Body Control Module also.
  15. starlifter
    starlifter Member
    Pennsylvania
    had my BCM replaced last week. in the year I've had the car, that's two 'major' components (including an AC compressor). perhaps three if you include the seals for the FWD's.
    Don't get me wrong, the SC has been fantastic. quick, efficient and loaners. But I hope all major issues are resolved long term before the warranty runs out!
  16. sorka
    sorka Active Member
    Merced, CA
    I'm having the exact same issue. Have taken multiple videos showing that I can't get back into the car unless I double tap the top of the fob.
    So have folks who had their BCM replaced not seen this again after? Did this issue really only start after the software update in October that added the "passive entry" feature?
  17. AdamHLG
    AdamHLG Member
    Baltimore, Maryland
    my car is working fine since the BCM was replaced.
