auto steer stopped changing lanes
Discussion in 'Model X: Driving Dynamics' started by Adityarad, Jul 1, 2018.
  1. Adityarad
    Adityarad Member
    West windsor nj
    I have had the Model X since sept 2017 everything worked fine on the autosteer all of sudden since the last update when i turn on the turn signal the autosteer disengages? anyone else have this issue? did not find it on the forum.
  2. P85_DA
    P85_DA Supporting Member
    No issues on mine AP2.5 on 24.1 ...would help if you listed out what your AP S/W version is so other folks can chime in as well
  3. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    Mine works fine on 2018.21.9 and 2018.24.1. Did you reboot after the firmware install? Good to make that a habit. Try rebooting now.
    And check the settings. Sometimes an install will mess with them.
    And, yes, include your firmware version or put it it in your sig. it’s the most important piece of information when discussing an issue. :D
  4. Leo Snow
    Leo Snow Member
    Ontario
    Check if the option off or on... It depends on updates sometimes, I got it turned off eventually after another update and thought that something is wrong with the car.
