Auto Suspension Adjust Help
Discussion in 'Model X: Driving Dynamics' started by tessla, Sep 21, 2017.
  1. tessla
    tessla Member
    Boston
    Hi Everyone!
    My new MX will auto-raise the suspension, at locations i had set, but not auto-lower.
    I noticed that when i raise the suspension at a location, a spinning wheel will occur, and mentioning that it is memorizing the location, and i would even have that "x" button to cancel the memory from happening.
    However, when i lower the suspension to "very low" at a destination, the car lowers, but it doesn't memorize that setting. Is this only a raise suspension feature?
    We have the dogs in the back, and its nice to get home and have the car auto lower to "very low".
    any advice would really help!
    Thanks!
  2. vandacca
    vandacca ReActive Member
    Hamilton
    Yes, for some reason, it only GPS-saves ride suspension height for High and Very High. Send an Email to [email protected] and ask for this feature. I did over a year ago, but if we get enough people requesting it, maybe it will be added in a future OTA update.
  3. tessla
    tessla Member
    Boston
    Thanks! I actually just called tesla and asked them about it, and the service tech told me it should do it. So i was really confused. But it honestly just seems like the feature is not available.
    Am sending an email right now.
  4. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    If they said that, they can't read their own manual. :D
  5. animorph
    animorph Member
    Scottsdale, AZ
    When you raise the suspension manually or by GPS it only lowers when you exceed the fixed speed threshold for that setting. Not really a complete geofence. Manual lowering has no specific trigger that would raise it again, I think. Tesla would have to geofence around the manual lowering GPS location, but that would also involve a decision, or another setting, about the size of the area it would use. Not a big problem, but different than their current model of operation.
  6. FlyF4
    FlyF4 Member
    Sparks NV (Giga-Town)
    While on the subject, I'll ask this question in case some of you folks know the answer. I exhausted my factory contacts whom don't know the answer. Then again, they don't specialize in this area.
    Soooo, how do I clear my model X memory of the past height adjustment locations? There are two places around here where I used to need to raise the height to prevent bottom scraping, but now in the last year, they fixed the roads in those areas, so the X still wants to unnecessary raise the car at those locations. Unnecessary wear.
  7. Yinn
    Yinn Active Member
    Behind you
    Pull up your suspension setting screen. When you get to the location, it will change to High or Very High, to the right you'll see a new box that says Auto Adjusting or something to that effect with an X. Tap the X to remove it from memory.
  8. FlyF4
    FlyF4 Member
    Thanks Yinn. I should have mentioned that I was aware of that ability to clear an INDIVIDUAL setting. What I am looking for is an easy way to remove ALL height adjustment settings.
  9. Yinn
    Yinn Active Member
    Behind you
    Ah ok. The only way I know how would be to reset the car, but that would be a PITA for everything else.
