[Apologies if this has been covered previously. My searches didn't yield this topic getting too much discussion.]
My wife and I took delivery of a Model Y almost 2 weeks ago. We want to charge based on "excess" solar coming off the panels - power that under normal circumstances would go back to the grid. Our primary motivator is to see if we can satisfy our car needs using truly renewable power (i.e. trying to avoid power that is generated from other sources such as natural gas, petroleum or coal).
I've written a program that looks at our meter and adjusts car charging based on whether we're returning power to the grid or pulling from the grid. No special car charger is required. (We charge with a NEMA 14-50 cable.) In the configuration we're using we have a small box from Rainforest Automation (Eagle-200; ~$100) that connects to your smart electric meter. The code I've put together can be run on whatever you have lying around. I'm using a Raspberry Pi.
Below find a link to a short blog post on the solution. I'll be giving the sw away (probably through GitHub) once I clean it up a bit and make various settings and configurations better documented. If there is sufficient interest here I'll add a response to this thread when it's in a more usable state.
Jim
Suncatcher: Coordinating Tesla Charging With Solar Panel Output
A few weeks ago I wrote of a project I was starting that would adjust the charging rate of a Tesla based on the electric production coming from solar panels. The goal is to "capture" excess solar...
jimhaselmaier.weebly.com
Jim
