Having issues with windows fogging up here in the Seattle area. My Volvo will automatically engage A/C when in auto mode. Is there a way to enable this setting so that I don't have to push A/C every time I get in to go drive? I know, first world problems.
I believe my M3 is enabled with same settings when I last left the car. If your a/c was set on auto when you left then it should be enabled when you first enter. You could also pre cool with your phone app remotely.
it is temperature dependent, if the ambient temp is higher than your set temperature then a/c will cycle on. You should just force the ac remotely long story short.
Keep AC switched on with the system set to Auto. In five months of ownership, my AC has never switched off, to my knowledge. The compressor runs when it needs to for cooling and/or dehumidification purposes.
yep, just leave the AC on auto and adjust the temp as needed. It has started every time for me in 6 months of ownership.
I also use the app to preheat if its chilly outside.
If you press Auto the A/C button will switch on, the humidity and temperature are controlled automatically. As soon as I press that my windows defog immediately.
