AutoPark
Discussion in 'Model S' started by radelman601, Sep 10, 2016.
Tags:
  1. radelman601
    radelman601 Member
    San Antonio, TX
    This may be a dumb question but...
    Will AutoPark detect and work with parking spots on the driver side (left) of the car?
  2. RogerHScott
    RogerHScott Active Member
    Lafayette, IN
  3. green1
    green1 Active Member
    Calgary, Alberta, Canada
    It works on both sides of the vehicle, however it has some very specific things it looks for. It needs a space the right size with a car both in front and behind, and it needs a relatively defined curb. If there's only a vehicle on one side of the stall it won't work, and if the curb is too gradual, or not tall enough it also won't work. You also need to be traveling at slow speed for it to detect them.
    On a new car, or after some software updates it also needs to spend time calibrating the sensors before it will see any stalls, and even after it claims calibration is complete, it seems to continue to improve that calibration for the next little while, so it may not see as many stalls at first.
  4. RogerHScott
    Lafayette, IN
    Word to the wise: just give up on the idea of ever demoing autopark to other people. It has an uncanny knack for choosing
    those occasions to refuse to recognize a spot and embarrass you. And certainly never attempt a spontaneous, unrehearsed demo.
    • Like x 4
  5. MikingCO
    MikingCO 2019 75D Model S
    Denver, CO
    I've also had some tense moments using auto park where there is a lot of traffic around. The process is super slow plus you typically have to pass the spot by a good amount before the car will give you the "P" on the 17". Other drivers tend to not have the requisite patience to make it a good experience.
  6. Austral
    Austral Member
    Even moderators don’t follow forum rules....
    On the upside, I used it today and it performed a flawless job between an SUV and a sedan with a normal city curb. The driver behind me gave me a wide berth to maneuver. It seemed like they were eating popcorn and watching the Tesla make its move. :)
  7. cipherstream
    cipherstream Member
    Canada
    Another question - Does it have the ability to back into a garage (straight back) similar to how you would program summon mode from your app?
  8. fallen888
    fallen888 Participant
    Newtown, PA
    That's exactly want happened to me today. I refused to accept it and kept driving around the lot for a bit. But ended up giving up after five minutes. I was definitely a bit frustrated.
  9. RogerHScott
    Lafayette, IN
    Sure, it works in either direction.
  10. cipherstream
    cipherstream Member
    Canada
    thanks! I'll have to figure out how to make this work
  11. Phoenixhawk101
    Chicago, IL
    I do this every night.
  12. Lightmatrix
    Lightmatrix Member
    Houston, TX
    Press the park button on the stalk twice and your car will ask which way you want it to roll after you exit.
  13. cipherstream
    cipherstream Member
    Canada
    thanks for this! will try this out!
  14. hybridbear
    hybridbear Member
    Minneapolis
    This has been my experience too! So annoying! There have also been times where I would prefer to let it park itself (such as when there is no traffic behind me) and it never is willing to autopark then! But when there's a lot of traffic around it is willing to autopark. In those situations I often prefer to park myself since other drivers like to get so close behind... The couple of times that it has wanted to autopark but I have chosen to park manually the center screen has frozen when I hit the "not this time" button. This has resulted in me having to parallel park with no backup camera since the camera froze on the frame shown when I pressed the button. Fortunately the proximity sensors still worked. Tesla says it can't find anything wrong with my car. My center screen freezes at least a couple times per week.
  15. vitesse
    vitesse Member
    Hertfordshire (UK)
    Sorry to revive an old thread - I'm hopefully getting a 2016 Model S soon (AP1) and was wondering if autopark will mean avoiding the wheel rims scraping the kerb? Has anyone used auto park and still contacted the kerb? Also, if parking manually, does autopilot warn you if you are about to get too close to the kerb? Thanks!
  16. pedriscoll
    pedriscoll Active Member
    Indianapolis, Indiana
    Personally I Have found autopark to be useless. It is very hit or miss in recognizing parallel parking spots. For perpendicular parking I can back in much faster on my own. However, when it does work, it would likely help you avoid curb rash.
  17. rhumbliner
    rhumbliner Member
    Jackson.Hole Las.Vegas
    I use auto park with my 2016 MS all the time and have yet to hit the curb. I also don’t understand the complaint that it’s too slow. It’s faster than me doing it manually but maybe that says more about my parking skills. :(
  18. AwlBidnz
    AwlBidnz Old Guy to be driven around for yrs to come
    Edmond, Oklahoma
    Autopark is annoying many times. It has "allowed" me to become comfortable with the rear camera graphic & the tilted rear view mirrors, for accurate parking. I'm getting pretty good at it ;0) Another interesting upgrade is that I get the "P" symbol many times when I am waiting at a light with cars all around. I've never dared it to park in that situation tho ;0o
    • Funny x 2
  19. RogerHScott
    Lafayette, IN
    It doesn't try to park particularly close the the curb, so I don't think curb rash is much of an issue. As for how well it works in general, I've had many occasions when it didn't identify a spot I thought it should, but only one that I can recall where once it tried to park in a spot it was unable to do so. However, the problem of needing there to be essentially no traffic on the street you're parking on remains.
