Gizmotoy
Those seem like some mighty fine made up numbers! According to most research, the average unit cost of an EyeQ3 is $44. To get to 5 you need 4 more, so that's ~$100. It's going to be hard to get to $10k from there with 6 additional cameras, two of which are likely integrated into the front unit and share an assembly.Such a hardware suite would add $10k to the price of the car (a little more than half of it is cost), and it would hamper the performance and mileage of the car by 10%-20%. Not to mention when launched it will be far from perfect and will require as much attention on autopilot 2.0 as autopilot 1.0 requires. It launches as a tool, not a take-over. Still awesome though. I doubt the timeframe because Musk is always bad with this type of thing, but it is technically possible. The problem though is that we have yet to see Tesla research mules in the city taking intersection after intersection so they still either have to build the 5 eyeq3 prototype or if it is built collect the data required before moving on to the next step. While they have plenty of data from behind and in front, Tesla has little data from side angles.
The performance and efficiency reduction seems even more unlikely. How do you get to a 20% performance and range reduction from a couple cameras and circuit boards?
